7-14mm or 8-25mm...Update
  • 7-14mm or 8-25mm...Update
    Difficult decision
    Quite a bit of difference.
    23
    7-14 f2.8
    30.43%
    7
    8-25 f4
    69.57%
    16
    The poll is expired.
    I switched from the 7-14 to 8-25. Slightly longer focal length, plus standard front element outweighed the one stop and 1 mm.
    Celeste
    • Shaw
      Shaw commented
      Same here!
    • JeremyB
      JeremyB commented
      Me too, for the exact same reasons! The 8-25 is just a more versatile lense, and paired with 12-100 they make a perfect combo for me.
    • mikero
      mikero commented
      Same here. Not only that, but the 7-14 'suffered' from severe field curvature which meant that you really needed to stop down to get a sharp image front to back and into the corners. So for me, the F2.8 aperture was largely wasted.
    What will you do if it's a draw, Dave?
    That's a very difficult decision. I have the 7-14mm f/2.8 and very seldom use it. But when I need it, I really NEED it. That's why I still have it. Most of the time, 12mm is wide enough for me. That is why the 7-14 gets so little use.
    If I had the 8-25mm f/4, then it would probably get a lot more use as its zoom range makes it a lot more versatile for me. It could serve as a general purpose walk-around lens for street or scenic photography. But that also adds to the confusion. I'd constantly be mulling over whether I should also take another (longer) lens along with me or not. I probably would........ Adding to weight.
    So......... In the final analysis, if I had neither, I would probably opt for the 8-25, but it would be a very close call. But if I had the 7-14 (and I do), then I wouldn't change.
    Larry Griffiths
    Lenses: Too many to list.
    • Ross the fiddler
      Ross the fiddler commented
      Good answer Larry. Going on Dave's record, if he finds it heavy it would be for sale in a short time too, then he might have sellers regret & buy another only to end up selling that too (like he did with the 100-400 lens).
    I use filters, it would have to be the 8-25
    Iain
    MC-14, MC-20
    Website
      For taking photographs, the 7-14 great, especially indoors. For taking videos, the 8-25 quite exceptional everywhere. And I then did sell my 7-14.....
        Shouldn't 8-18 be in the poll too?
        • pdk42
          pdk42 commented
          In theory, but hard to recommend the 8-18 over the 8-25, esp to Olympus users.
        7-14: Big. Heavy. Bulbous front element. Doesn’t take filters. Uber wide, but long end is only 14mm.
        8-25: Lighter. Shrinks down for storage. Concealed front element. Takes filters. Still very wide, but more useful at the long end.
        You can guess where my vote went!!
        Biggest question though is “why do you want a UWA zoom?”
        I have the 7-14mm. Works very well, but I suspect I would used the 8-25mm more...
          I have the 12-100 and feel I want something wider.
          The 8-25 gives too much overlap with the 12-100.
          And as can be seen from the above shot is surprisingly narrower than the 7-14.
          • pdk42
            pdk42 commented
            Yes, but what are you wanting to photograph that needs something wider? If it’s landscapes, filters are almost a necessity making the 8-25 the hands-down winner. If it’s interiors then the 7-14 wins because of its wider FOV. If it’s Astro, the 7-14 probably wins due to its wider max aperture. If it’s general walkabout with a wide flavour, then the 8-25 wins because of its better range, etc, etc
          Having had the 7-14, my answer would have been for the single shots that required the UWA that couldn’t be done with sweep panorama or a 9 shot stitch.
            Difficult decision
            Yes, but how important is that extra bit of FOV? 8mm is still pretty wide. It’s 16mm equiv in FF, and the 16-35 has been a long time staple of Pros who need a wide zoom.
            • MikeOxon
              MikeOxon commented
              Don't forget that for static scenes you can pan and then stitch multiple photos..
            For you Dave, I would suggest the 8 - 25 at
            411g (without lens cap, lens rear cap and lens hood)
            While the 7-14 is 534g
            Being able to use filters directly on the 8-25 & with a larger range is another advantage.
              I did have the 7-14 for a short while but found the focal length range too restricting for me to use the lens regularly. As others have said, it is a heavy lens, and the inability to use filters on the front is another disadvantage. The 8-25 is a much more versatile lens, though a bit slower and less wide, but with the extra range it can be used as a walk around lens and I find it superbly sharp throughout.
                One thought is with the overlap 8-25 v 12-100 (which dave has) the overlap cuts down changing lenses compared to 7-14
                • JeremyB
                  JeremyB commented
                  Precisely. That's exactly what I found when I was using my 7-14 and my 12-100. I bought the 8-25 shortly after it came out last year, and sold the 7-14 a few weeks later. I miss the wider aperture, but not so much to make a big difference to me.
