Out for my morning walkies today and a thought struck me , we are always harping on about what can be done to improve our cameras , but there’s one significant improvement that could easily be done and that’s to replace the SD card slots with the far faster XQD cards or the newer CFE cards .. having used the former in my Nikon the read/ write speed of these cards is phenomenal. Here’s hoping
Wish they would
SD cards are the least troublesome bit of the kit. No real problems with them, but I rarely use high burst of photography. The video copes withb60 frames / sec, so don't see the need for ultra fast cards, for me anyway....
But it does seem to have been taken up by the opposition . Till you actually try them and see you don’t realise how fast they are I.e I downloaded 95 Raw files from a XQD card today took around 5 seconds ..and it will write to the card fast in camera to I think the D500 is rated to a 100 shot buffer without falter .
It’s just a thought anyway but I’ll bet you see it in OMS cameras within a year or two most likely be the latest generation of CF express cards as there quiet small
With the OM1 I have just changed to Sony tough cards and the burst mode in the camera is superb now - prior to getting these I could easily max out hte buffer with birds in flight. The change for me was a really worthwhile upgrade, transferring to pc is still slow though....but that's probably due to my old card reader.
I don't think the camera needs any faster cards, bearing in mind it's not a high mp sensor, just wish the sd cards were a little cheaper for the higher performing cards.
Matt
Unless you’re doing video at high res and high frame rate I don’t think SD cards present any limitations. They are these days available with good read/write speeds that are plenty good enough for stills. XQD and CFE cards are also much more pricey.
That is very occasionally the case in my experience with the OM1 mki, but the mkii’s buffer is much bigger, and if you run out of space on one of those with a recent UHSII card from SanDisk, Lexar, Prograde etc I’d wonder if your trigger finger might be a bit too heavy 🤣Originally posted by Matt_Hirst View PostWith the OM1 I have just changed to Sony tough cards and the burst mode in the camera is superb now - prior to getting these I could easily max out hte buffer with birds in flight. The change for me was a really worthwhile upgrade, transferring to pc is still slow though....but that's probably due to my old card reader.
Matt
As Paul says, the more exotic cards are a lot more expensive.Regards,
Panasonic 8-18 & 15.
Thinking about it, I can't recall ever filling the buffer on either my EM-1, EM-1 Mk II or my OM-1 but I don't habitually shoot at very high frame rates. On my OM-1 I use 5fps for normal shooting and 10 for action such as birds in flight. I find these to be generally sufficient. If I were to photograph Puffins in flight (something I'm hoping to do at some point) I'd use a higher frame rate because they have a very fast wing beat. I probably would buy a couple of faster SD cards for that. Currently I use some now quite elderly 90MBs 16GB Sansdisks which have proven themselves sufficient over many years.Best wishes
Wildwood
I suppose it depends on where you are shooting and what you are shooting...the mk1 and older I have filled the buffer quite occasionally but it simply doesn't happen with the newer cards. The mk2 im aware has larger buffer and is of interest to me but I'd probably wait for the next version as the rest of the tech in the camera is not a big enough jump from the mk1.Originally posted by drmarkf View Post
Matt
- Likes 2
Yes, for sure.
On my recent 3-week trip to S Africa I took a sheaf of 64Gb UHS-II cards, mostly Lexar, and filled 10 of them with a mix of safari wildlife and birding, including quite a bit of ProCapture (plus some landscape and 'travel' shooting). I went with the intention of keeping all the original cards as taken - that way I didn't have to carry a laptop & backup HD/SSD drive(s), or one of the proprietary stand-alone SD backup drives, or spend the time each lunchtime & evening copying all the files off the cards and formatting them.
I did that the last occasion I went to Africa and I must say I enjoyed my trip more this time, and having a much lighter carry-on bag was a blessing..
I dread to think what the cost of 10 exotic cards would be, so one would need to take a laptop!
I mostly use short bursts of maybe 5-10 images, although some safari wildlife encounters involve a huge amount of action over several minutes or more, and that really does burn the storage. For general use I'm at 15fps, although if I'm birding I will sometimes set it higher to capture a greater range of wing positions - 50fps really does give more useful choice.
