But why?
  • But why?
    Probably in the wrong forum.
    Last night my desktop running windows 7 suddenly started saying "user profile service failed the login"at the start-up page and not letting me load my desktop.
    On my wife's account I could log in no problem.
    I played around this morning and found this with a Google.
    Click Start, type regedit in the Search box, and then press ENTER.
    In Registry Editor, locate and then click the following registry subkey:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
    In the navigation pane, locate the folder that begins with S-1-5 (SID key) followed by a long number.
    Click each S-1-5 folder, locate the ProfileImagePath entry in the details pane, and then double-click to make sure that this is the user account profile that has the error.
    If you have two folders starting with S-1-5 followed by some long numbers and one of them ended with .bak, you have to rename the .bak folder. To do this, follow these steps:
    Right-click the folder without .bak, and then click Rename. Type .ba, and then press ENTER.
    Right-click the folder that is named .bak, and then click Rename. Remove .bak at the end of the folder name, and then press ENTER.
    Right-click the folder that is named .ba, and then click Rename. Change the .ba to .bak at the end of the folder name, and then press ENTER.
    If you have only one folder starting with S-1-5 that is followed by long numbers and ends with .bak. Right-click the folder, and then click Rename. Remove .bak at the end of the folder name, and then press ENTER.
    Double-click the folder without .bak in the details pane, double-click RefCount, type 0, and then click OK.
    Click the folder without .bak, in the details pane, double-click State, type 0, and then click OK.
    Close Registry Editor.
    Restart the computer.
    Log on again with your account.
    Here's a link
    I don't like playing around with registry entries on PC's but it worked fine.
    But why did it happen in the first place?
    Though I'd post this just in case anyone else gets it.
    Ps glad I loaded my wife's profile as an admin otherwise I assume I'd have been piddling with safe modes etc.
    All the best
    Lots of cameras and lenses.
    Re: But why?
    Yeah, well - 'Windoze'!
      Re: But why?
      Well there's a strange one; I had the same this morning on XP SP3 when I started Opera with several tabs open. About half of the tabs which should have logged into a newsgroup, this one amongst them, displayed a similar message.
      The only way I could get it to clear was to close the tab and re-open it.
      Also about half the time I try and post a message on here, I get
      You tried to access the address http://e-group.uk.net/forum/newreply...treply&t=26358, which is currently unavailable. Please make sure that the web address (URL) is correctly spelled and punctuated, then try reloading the page.
      After two or three goes of hitting the back button and re-submitting the post, it works fine.
      Last edited by peak4; 31 March 2013, 06:42 PM. Reason: Added bit about posting issue
      Best Regards
        Re: But why?
        Sounds a bit iffy, two users having a similar problem about the same time. My brain's starting to think malware ....
          Re: But why?
          Malware sometimes alters the registry, I've seen similar before on XP.
          Time to run MalwareBites etc Andy.
            Re: But why?
            Already done so, nothing shown and no further problems. Touch wood
            Best Regards
              Re: But why?
              Don't know if this has any bearing, but when I loaded Viewer 3 the other day, my lappy froze up solid after the immediate update.
              I am totally comptuer illiterate, so Andy's post was so much goobledygook to me, but I unistalled Viewer 3 and everything went back to normal.
                Re: But why?
                It is the 1st of April now (here)!
                  Re: But why?
                  A couple of times in the past fortnight I've had the dreaded 'enter network password' message. On investigation I found it wasn't an Outlook problem but one connected with Yahoo. When I tried to log in to my Yahoo account from Firefox I was told my computer was not recognised and had to enter a piece of memorable information. I then had to change my password, after which all was fine until it happened a second time.
                  I can only assume that somehow the IP address of my computer changed but I've no idea how or why. Can anyone shed any light please?
                  EM1ii, EM10ii
                    Re: But why?
                    Unless you have a fixed IP address from your ISP then you could get a new one after restarting the modem/router.
                      Re: But why?
                      BT fitted a new modem earlier in the month but I don't think that was the cause of the first message. The modem and a bit of tinkering with the incoming line have increased both speed and reliability.
                      EM1ii, EM10ii
