Deeper eye cup OM1
  • Deeper eye cup OM1
    Can across this on Amazon
    That looks interesting. Did you order one?
      I wonder if it would have a benefit or disadvantage for glasses wearers?
      • blackfox
        blackfox commented
        definite benefit I use one on the mkiii
      Good to know
      Is yours the same shape/size as the one mentioned by the OP as when when added to the glasses puts ones eye a marked distance away from the viewfinder.
      • blackfox
        blackfox commented
        I have used the JJC extended eyepieces on both the I-mkii and 1-mkiii .one of the better Chinese companies there products tend to do what it says on the box . . and it does help if you wear specs to
      <iframe sandbox="allow-popups allow-scripts allow-modals allow-forms allow-same-origin" style="width:120px;height:240px;" marginwidth="0" marginheight="0" scrolling="no" frameborder="0" src="//ws-eu.amazon-adsystem.com/widgets/q?ServiceVersion=20070822&OneJS=1&Operation=GetAdH tml&MarketPlace=GB&source=ss&ref=as_ss_li_til&ad_t ype=product_link&tracking_id=digitalphotog-21&language=en_GB&marketplace=amazon&region=GB&pla cement=B0B2PPTZRH&asins=B0B2PPTZRH&linkId=2ab88d38 415ae5e5e6ee9d2d305da14b&show_border=true&link_ope ns_in_new_window=true"></iframe>
      .... There's no link to the product showing on my system.
      My Flickr pages
      • Ian
        Ian commented
        I had a glitch with the code when I was posting the image and link - is it visible now? If not, the link is https://amzn.to/3xuT5ED
      • RedRobin
        RedRobin commented
        Ian, thanks - It doesn't show in the original post but thanks for the Amazon link.
      I will be ordering one but from a different seller......the short video on both sellers pages is identical but the pictures are a different mix. The reason I have gone for this seller is that it is Dispatched from Amazon not the merchant IMO much easier to deal with Amazon than the merchant directly
      PROfezzion Extended-Type Soft Silicone Eyepiece for Olympus OM SYSTEM OM-1 Micro Four Thirds MFT Mirrorless Digital Camera Replaces Olympus EP-18: Amazon.co.uk: Electronics & Photo
      I will let you know what I think once received & tried on the camera
      • RedRobin
        RedRobin commented
        I look forward to reading what you think of it in practice Box Brownie. Then I might consider getting one.
      RedRobin
      I am hoping as a glasses wearer and left eye shooter that I can see the EVF clearly without feeling like I am looking down a tunnel.
      Plus that less chance of my nose pressing on the LCD and the extra space/distance will aid my right thumb accessing the controls that bit easier
      • Regor250
        Regor250 commented
        The further away your eye, the less of the screen area you will see. I find I can barely see the entire screen with glasses as it is, a deeper eyecup will make it even worse I would imagine.
      • RedRobin
        RedRobin commented
        Regor250 That's a very good point. However, in my case I don't wear glasses when shooting.
      • Ross the fiddler
        Ross the fiddler commented
        I agree Regor250.
      Thanks for the link. I have ordered one too.
      I have the deeper Olympus eyecup on my E-M1 III and have been 'keeping an eye out' for a solution for my OM-1.
      • thecedars
        thecedars commented
        What eye cup do you use on the Mk3? Does it help when wearing glasses? Thanks
      • YellowHound
        YellowHound commented
        IIRC it's the Olympus EP-13 eyecup. I don't wear glasses when I look through the viewfinder so can't comment on that aspect.
      • thecedars
        thecedars commented
        Thanks - that's helpful.
      OK, my first impressions following my first day with the deeper eyecup for the OM-1 :
      It does place your eye a few millimetres further back and hence can reduce your view of the whole EVF area. BUT, all you have to do is lean your face in to compensate and the rubber is very soft and comfortable and easily allows this.
      The big advantage to me as a wildlife and surfer action photographer mostly using telephoto lenses is that because I have learnt some time ago to nearly always shoot with both eyes open, it is now much easier to have simultaneous sight of being both inside and outside the viewfinder and consequently to spot a target rather than be lost in a narrow telephoto tunnel view desperately trying to find it!
      My Flickr pages
        Well, picked up my Amazon parcel from the local hub.
        Though I ordered it from another reseller who Amazon dispatch for, it was in a branded box by the other one KiwiPhoto.....but had an oversticker of the supplier name I chose! Furthermore under the shrinkwrap there is a JJC sticker.
        I will trying it out in due course
        • RedRobin
          RedRobin commented
          Mine was packaged in exactly the same way with the same branding throughout except no over stickers. I ordered from Amazon and received it 2 days later with free shipping.
          Am very happy with it so far - As my Post Albums above.
        Update
        A tad later than intended....
        Tried it and in my case, with my glasses, it does not yield an improved EVF view......but a worse one!
        It will be going back for a refund.
        C'est la vie
        • RedRobin
          RedRobin commented
          I don't usually wear my (variofocal) glasses while shooting but tested it just to see and it also made my EVF view worse too! But I like it very much for the reasons I already said in my Comment # 9.
        • Box Brownie
          Box Brownie commented
          I wear varifocals too but being shortsighted can't dispense with them.
          One thought that did occur to me would be to trim the eyecup flatter than the current OEM one i.e. to still leave a cushioned edge to protect the glasses but the aim is to get a couple of mm closer. It may or may not work, so just trying risks wasting £15.99 !
        I'm interested and wear specs BUT it says ... soft yet durable silicone design is comfortable for those who do not wear eyeglasses
          I have one but did not like it, it needs to be cut to fit your eye better as to much rubber near your nose, I put the old one back on, using specs it maybe better??
          Edward
