Video Settings on EM1 Mark 3 with LSP4 recorder
  • Video Settings on EM1 Mark 3 with LSP4 recorder
    Hello! I just watched a really useful video on movie settings while using the LSP4 recorder. It mentioned a PCM Recorder Link setting. I don't seem to have this setting on my Mark 3. Any ideas? I also just updated the firmware! Thanks.
    Sisi Burn
    Photography for musicians.
    www.sisiburn.com
    Which useful video?
      Which useful video?
      Hey Olympus team, a bit of a long one today sorry. But I really think it’s worth it for those of you considering adding an audio recorder to your kit. It rea...
      Sisi Burn
      www.sisiburn.com
        That setting was removed from the Mk3, I am pretty sure he has a Mk2 there which has it. The PCM recorder link was for a USB connection between the recorder and the camera so they they could be synchronised over USB and the camera / audio recorder can be controlled together for video. I think it was only supported on the LS-100 recorder and Olympus have dropped it. It is puzzling that both devices have Bluetooth and they do not do the same function over that connection free. The only use for Bluetooth on the recorder I found is for Bluetooth headphones and for controlling it from an Olympus Android app to turn it on / off.
        I posted some of my own experiences with this recorder here if it is of any help:
        I decided to get an Olympus LS-P4 audio recorder to capture ambient audio for some projects creating short wildlife videos from clips when I go around nature reserves. I thought I would write up my findings in case anyone else is interested in trying this. I had seen this setup at the Photography Show last year where someone
          Ah Ok. Thank you very much. That would explain it then. Thanks. I will take a look at your link.
          Sisi Burn
          www.sisiburn.com
            I am using it mainly in the studio to record voice. Trying to work out if it is best to have it as a gun mic on camera or on a separate stand off-camera. Also, need to avoid camera noise and loud background hiss/hum.
            Sisi Burn
            www.sisiburn.com
              I found with it mounted on the camera there is some rumble that comes into the audio from the IS mechanism of any IS lenses you might use like the 12-100mm F4 or 300mm F4 and some lenses have some noise from focus motors. So mounting off the camera may be better in some situations and also putting it closer to your subject will help.
                Hi Bill, you might know the answer. Do any of the Olympus cameras offer sound monitoring via a jack for headphones? Thank you
                All the best
                Phil
                  My E-M1 mkII has a headphone jack.
                  Iain
                  MC-14, MC-20
                  Website
                    Good question on monitoring. As IainMacD has said both the E-M1 MkII and MkIII have 3.5mm stereo headphone jacks and I can confirm that you can monitor audio during video recording. I just tried it - plugged in some mini earbuds and turned the dial to video and you get the live audio while setting up and during recording. I have never used it before but it seems like a good way to see how much handling noise the on-camera mics can pick up 😂
                      Thank you, both excellent replies
                      All the best
                      Phil
