Big White lens Cap LC-115
  • Big White lens Cap LC-115
    I am fortunate to have a 150-400 lens which I am very happy with, with one exception - The lens cap. When using with the lens hood on the lens it does not fit well and keeps coming off. Being a cheap Scot I have used disposable shower caps (acquired when staying in hotels) but I am looking for something more durable! Does anyone have any suggestions about suitable alternatives for a lens cap that can be used with the lens hood on? Hopefully that makes sense.
    Thanks in advance.
    This lens takes a 95mm cap. The Version 2 Zemlin Photo lens cap is 3D printed fiberglass-reinforced ABS plastic. The tough urethane Skid Pad grips smooth surfaces when the lens is placed face down on a table top or smooth floor. Screws and spring wire are stainless steel. Lens cap can be installed or removed with the lens hood in place. Unlike the Version 1 cap for this lens, the V2 95mm cap can be used with a filter mounted on the lens.
    I just use a cheap one from ebay- about £8.00
    Edward
      The lens cap on the 150-400 is designed to be used when the lens hood is reversed for storage. Hence strap goes round the lens hood attachment knob. I've never used the lens cap when lens hood is pointing forward.
      The lens hood is large enough not to require a lens cap when lens is horizontal or pointed down when carrying.
      I do use an Urth UV filter as a just in case protection again rain and my lens cleaning skills.
      As rustyarrow points out there are plenty of 95mm lens caps if you prefer. These are probably a good idea on windy days when the large lens hood makes lens less manageable and needs to be removed.
      Gary
        If you want a to keep with a good quality and good fitting traditional clip in lens cap to correctly match the lens, then use the cap from the 150 - 600 "LC-95 Lens Cap".
        Personally I have not found the need for a lens cap once the hood is fitted. The lens hood provides good protection.
        Derek
        www.dncphotography.co.uk
          Like gazza95 I don't use a lens cap when the hood is out (and also use an urth filter). I have a cheap 95mm lens cap from amazon for using when the hood is reversed. It will fit when the hood is out (just tried it) but is a bit of a fiddle getting it securely on with the hood on.
            Originally posted by rustyarrow View Post
            https://www.zemlinphoto.com/product/...ategory_id=113
            I note Zemlin also do alternatives to the supplied lens hood.....
            I wonder what, in practical terms, in the field using the short version vs the 'matching' size version would make? Though they also do a 2 part version with if I read it right an available mini attachment for use with the lower half of the 2 part model.
              I have bought a Sigma 95mm lens cap for the BWL. It fits well.
              Sigma Photo | Continuing to produce the heritage-rich and award-winning SIGMA cameras, lenses and cine lenses
              Larry Griffiths
              Lenses: Too many to list.
                https://www.zemlinphoto.com/shop/m-zuiko-150-400mm-f4-5-tc1-25x-is-pro/112?page=1&limit=30&sort_by=category_order&sort_or der=asc
                The lens hoods seem expensive when the lens hood from the 150-600 is the same fitting and retails at £89.99
                Derek
                • Box Brownie
                  Box Brownie commented
                  Ah! Interesting .......
                  The LH-76 for the 100-400mm is a suitable fit for the use on the 40-150mm f2.8 in place of the beautifully engineered but reportedly fragile LH-76D
                  So, in regard to the £500 hood for the 150-400mm the above is a budget worthy alternative, needed.
                What I have done is replaced a 95mm X 30mm screw on hood and a 109mm pinch lens cap outside the hood. I am now waiting for the lens coat to arrive.
                  Gary
                  Thanks Gary - I use the lens cap to try and prevent dust etc getting on the lens when carrying or in the car - need something quick to remove. I am not a fan of filters as in my experience they have had an impact on image quality. When I had a Canon 500mm lens I used a tupperware lid on the lens hood.
                  Cheers
                    Hi John
                    Tupperware reminded of the in our kitchen;
                    * Flexible and stretchy bowl covers * Reusable and reduces the need for single use plastic film * BPA Free * Heat resistant to 230 degrees C * Fridge/Freezer, dishwasher and microwave safe Keep it fresh with our set of 6 flexible and stretchy bowl covers. With sizes ranging from 21cm to 6.5cm, these reusable covers are a sustainable alternative to single-use plastic film. BPA-free and heat-resistant up to 230 degrees C, they're fridge/freezer, dishwasher, and microwave safe – making them the ultimate kitchen companions.
                    • nc_killie
                      nc_killie commented
                      ...I also use those disposable shower caps that you get in hotels - a few nice words to housekeeping usually gets you a few extra! Great on safari to keep dust off and quick to get off!!
