Fish-eye and De-fish
  • Fish-eye and De-fish
    Helmut Dersch.)
    The following images show the results of 'de-fishing' one of my photos from Wadesdon Manor, using the PanoTools plug-in:
    For comparison with a more conventional lens, the image below marks the area covered by my Olympus 9-18mm zoom, when used from the same location. as the Meike (de-fished).
    Finally, an image that can only be made with a super-wide lens - this is the 'de-fished' view from the Meike, looking vertically upwards from inside the Dairy Court at Chastleton House:
    Re: Fish-eye and De-fish
    The "de-fishing" seems to work very well, although there is still a bit of distortion. Inevitable I suppose. I use my 9-18 a lot in such places and am generally pleased with the results. DxO does a good job of removing the minor distortions and aberrations. I'm quite surprised at how much extra the fisheye can see. I have the 16mm OM full-frame fisheye but I doubt the f-o-v on mFT would be much wider than the 9-18. I suppose I should try it and see!
    Richard
      Originally posted by Otto View Post
      ......... I'm quite surprised at how much extra the fisheye can see. ..............
      So was I, when I first saw the de-fish results .
      The settings for FOV in the PanoTools menu are quite critical for controlling the curvature at the edges. Since I first posted, I've made a further small adjustment to the second image, which has helped a little.
      My fish-eye shots were all taken at f/2. Possible a smaller aperture would improve edge definition but my objective was to test the low-light capability
        That's really good, especially considering the cost of admission.
        I'm looking forward to seeing what the new range of Laowa ultrawide and FE lenses for MFT can do. Their 7.5mm has extremely low rectilinear distortion, and stopped down a bit gives superb results. These are likely to be significantly more expensive than your lens, but still considerably cheaper than anything Oly/Panny are ever likely to produce.
        Panasonic 8-18 & 15.
          Small enough to fit in my bag and certainly a good price. Your de-fished reults look very promising.
            Originally posted by OM USer View Post
            ............ Your de-fished results look very promising.
            I tried photographing a large wall from very close, to test the de-fish performance. The brickwork itself was not perfectly even but this is the result, before and after de-fish:
            To test resolution of the Meike 6.5mm towards the edge of the frame, I took the following shot at f/8 (looking vertically upwards) and then compared with an actual-pixels area, near the edge:
