lenses
  • lenses
    Macro 4/3rds to 4/3rds like E-420?
    has anybody tried it? putting a Micro 4/3rds lens to say an E-420etc.body
    If it works we would have more lenses to choose from
    It works the other way with an adaptor that doesn't put the lens so close to the censer but if that is all, the difference between them is 18.67mm
    so if you put a lens with a 20mm flange onto the body compared to 38.67mm flange?
    answers on a postcard
    Robb
    "GOSH" I will get it right !
    Re: lenses
    Ermm. it just won't work, simples!
      Re: lenses
      If it's as simple as distance, like to far away, it's no different as to using a Canon lens with an adaptor, I know AF won't work but manual does I know cos I use old glass. Thoughts
        Re: lenses
        Because the m4/3 lens would need to be inside the 4/3 body and you would probably smash the mirror on the lens the first time you fired the shutter. And that would be the least of your problems.
        David M's Photoblog
          Re: lenses
          If all else, focussing would be impossible as m4/3 lenses are focus-by-wire.
            Re: lenses
            Originally posted by StephenL View Post
            If all else, focusing would be impossible as m4/3 lenses are focus-by-wire.
            As would setting aperture unless the adapter included electrical connections, that's what I meant by the least of your problems.
            David M's Photoblog
              Re: lenses
              No, because the M43rds Flange Focal Distance is 20mm to the sensor
              as the 43rds is 38.67mm
              so the m43rds will go into a 43rds body with 18.67mm to spare so to say
              YES
                Re: lenses
                So ... you want to take an m4/3 lens and push it inside your 4/3 camera body by nearly 2cm!...
                chris
                shetland
                  Re: lenses
                  OP is trolling?
                  no worries.
                    Re: lenses
                    Originally posted by Ulfric M Douglas View Post
                    OP is trolling?
                    Maybe, I've seen the same post on other 4/3 forums.
                    David M's Photoblog
                      Re: lenses
                      Be interesting to hear the sound of a mirror smashing on the back of a lens. 7 years bad luck, methinks!
                        Re: lenses
                        Better ask some Canon users. Apparently it can happen using certain legacy lenses on some Canon bodies.
                        David M's Photoblog
                          Re: lenses
                          sorry guys
                          you all on the wrong way round
                          I want to put an m43rds lens onto an E-420 body
                          Not the other way round
                          this is where I got lens Flange info http://en.wikipedia.org/wiki/Flange_focal_distance
                            Re: lenses
                            For the sake of repetition
                            4/3 lens ( with adapter) and m4/3 lens will work on an m4/3 body
                            4/3 lens will work on an 4/3 body
                            m4/3 lens will not work on a 4/3 body such as an E-410
                            chris
                            shetland
                              Re: lenses
                              OK chaps I give up
                              my head won't get round it but HaHo
                              I'll wait till my adaptor gets here, nikon to m43rds
