Factory reset on E-300
Re: Factory reset on E-300
From the good folks over the pond;
This works on the E-300
1) Set to P mode
2) Open CF card door
3) Switch on
4) Hold Playback+Ok for a few seconds
5) E-300 should display
6) Release and again hold Playback+Ok for 5 seconds
7) Press Ok to reset and turn off camera
It didn't cure the MF problem though and it's dark outside now, so I'll have to check out the colour issue tomorrow.
As one of the few lovers and users of the E-300, be advised to switch the white balance to 5300 on manual, and only reset it manually or it will drive you mad. The auto white balance has always been a problem, as is the difficulty to focus in low light, but given its few foibles, the E-300 can give you superb images with good lenses attached.The picture tells the story, great when you have a bad memory.DW.
