I love my E-M10 Mk.ii but recently it has stopped working. It turns on but with a blank screen and none of the buttons respond. Then after 2 seconds it powers down. I have tried new batteries, different lenses, different SD cards but it's always the same. It's out of warranty so just wondering if anyone knows about this issue and can help. Thanks.
Major Malfunction
Re: Major Malfunction
I've never heard of this problem either but you could try Luton Cameras as they are very good and reasonable for Olympus repairs. Best call them to discuss it rather than email. They have done a couple of lenses for me and I've been really pleased with the cleaning and the service.
How do you know it's powering on and powering down if no screen? I'm not familiar with the E-M10.Originally posted by SonetSeek View PostI love my E-M10 Mk.ii but recently it has stopped working. It turns on but with a blank screen and none of the buttons respond. Then after 2 seconds it powers down. I have tried new batteries, different lenses, different SD cards but it's always the same. It's out of warranty so just wondering if anyone knows about this issue and can help. Thanks.
The screen shows a blank (dark grey) area but no info at all and there is a sound of something activating. Then after 2 seconds the blank grey screen turns off, there is another sound and that's it. None of the buttons work at any time - only the power on/off switch.Originally posted by Ricoh View PostHow do you know it's powering on and powering down if no screen? I'm not familiar with the E-M10.
Not uncommon for systems to perform a 'health check' at power-up, and disable if a fault is detected to prevent further damage. But that's design practice in general. I have no knowledge whether Olympus do this or not.Originally posted by SonetSeek View PostThe screen shows a blank (dark grey) area but no info at all and there is a sound of something activating. Then after 2 seconds the blank grey screen turns off, there is another sound and that's it. None of the buttons work at any time - only the power on/off switch.
Weakest link in any design is generally the interconnects.
Maybe a stuck IS magnet?Originally posted by Ricoh View PostNot uncommon for systems to perform a 'health check' at power-up, and disable if a fault is detected to prevent further damage. But that's design practice in general. I have no knowledge whether Olympus do this or not.
Does the screen light up when the lens is removed? I have had the blank screen when the lens contacts were faulty. Data still showed around the edges of the screen.
Checking them and cleaning might help but I've had to have the contacts replaced on a couple of occasions. If it occurs with any lens, suspect the camera body; if only with one lens, then it's the lens.Mike
