Hi Walt, most hot pixels are just stuck pixels, if you run pixel mapping on your camera should fix this. Can be found in double cog sub menu K in the main menu, this will do a pixel test then if on finding a hot or stuck pixel it will generally fix it or mask it out, camera manufacturers, would not bother replacement of a sensor unless there are a certain number of them, that would degrade an image.
There should be a function with your camera called "Pixel Mapping" or something along those lines (I only have an E600 but i presume this function should be on a OM-DE-M1)
This may help...
Ooops looks like Dave beat me to it............ Good luck..........
Reason: someone got there 1st
