Olympus E-M1 II SD Card Comparison
Re: Olympus E-M1 II SD Card Comparison
I have already a 32MB Lexar with no problems in em1.2. After reading this, I've ordered another 64GB also from Lexar.
I do expect not to have compatibility problems... but clearly the recommendations from Olympus does not seem convenient.
I've learned with this camera test that we need to see what is the real speed in the specific machine, as it's quite sensitive to the reader. There is a recent Lexar's independent speed test that shows 2000X models having write speeds over 260MB/s (or so), however, in this camera test, the same cards are showing 100MB/s less speed. I'd expect the same happen with all other vendors.
Unless they tested multiple examples of each card and averaged the results small variances can pretty much be ignored. You could test 5 identical cards and get a spread of a few percent or so in the results.Originally posted by Graham_of_Rainham View PostAccording to the table in the link, the 64 Lexar is 2.6% faster than the 32 and the Transend 64 7% faster than the 32...
I'm going to guess that it's a circuit density thing...
