extract photograph from video
  • extract photograph from video
    Took a video and now decide to extract 1 of the many frames for printing. Is this possible?
    Re: extract photograph from video
    You'd probably need video-editing software to do that, but bear in mind the resolution of video frames is substantially less than full-frame so you will not get the same quality of print compared to a normal still photo.
    Richard
      IIRC you can do it with the free editing programs Virtualdub or Avidemux (Google is your friend!). You can also take a 'snapshot' with Faststone media player, and probably Irfanview - both also free.
        Olympus Viewer3 will do it. Its as simple as pausing the video and clicking on extract still. Will that work with your E-330(?) videos?
          So it is! I had no idea OV3 had video editing capabilities ...
          Richard
            Not many seem to give much credit or thought to using OV3, but it does do a fair bit really, even if I can do more with Capture One for raw processing, I still use OV3 mostly & still capture from video is one of the things it does fine.
              I have yet to try that. Now that you mention it, I did hear something like that when the OV3 was launch. Le me go try it out.
              E-330 can do video??
                This would work better if the framerate of the video is higher. A higher framerate is essential when doing moving video still extraction. If the video is slow moving or still- you're in luck.
                  If you can play your video on your computer, any decent player will be happy to extract single frames.
                  My personal preferences are Gom and VLC : very easy.
                  You don't need to use a video editor.
