Lost file
  • Lost file
    I seem only to be asking for help these days.
    I have an image in a Keynote presentation that I would like to copy, using a Mac. I click on copy, but cannot paste it anywhere, when I go to "Edit" the paste is greyed out. How can I recover that image so I could enter it in a DPI competition?
    sigpicDave
    You’re on a Mac right? You could display the Keynote slide with the photo full screen then take a screen shot of it with Command-Shift-3.
    It should then save a file to your desktop which might be good enough.
    Also Google turns up this solution, not sure if it will work as I don’t use Keynote often
    For those that are familiar with the "Save Image As…" option in PowerPoint might be disappointed to find that Keynote doesn't have this optio ...
    • sapper
      sapper commented
      Thanks for this, very helpful.
    Instead of taking a shot of the whole screen, you can use Command - Shift - 4 and then use your mouse to just select around the image itself by clicking and dragging around the image. Saves you from having to crop the full-screen screenshot. The default setting will save it as a .png file.
