Cropping query
  • Cropping query
    I have a series of photographs that need cropping to a panoramic size. The problem I have is that I want to make sure I finish up with exactly the same part of each shot, but if I do them all individually I'm sure to get them all slightly different. Is there any way of achieving what I want in Photoshop Elements 7 - or any of the other programs?
    Re: Cropping query
    I think I understand - Assuming your pictures were talking at the same place with very little movement this is possible
    I do AV shows and it's really useful when I've not had a tripod with me and wanted to take a set of images to show e.g. water or steam moving
    Not sure about elements, but you can defintely do it in Photoshop
    In CS3 you import a set of files using File > Scripts > Load Files into Stack and select the files you want to process
    Then ensuring that Attempt to Automatically align source images is clicked you can import them
    It pulls them all in as seperate layers which you then crop to your required size.
    You then need to check all the layers go to the edges by turning layers on and off (waste of time exporting if one of your pictures is missing an edge)
    Use File > Scripts > Export layers to files to take them back out
    My places
    http://www.shenstone.me.uk
    https://vimeo.com/shenstone
    http://swga.org.uk/
      Re: Cropping query
      Yes - they were all taken on a tripod. When I view them in slideshow format there is no (discernible anyway) movement and I'd like to keep it like that after I've cropped them.
      Thanks Andy - I'll see if Elements does something similar.
        Re: Cropping query
        Ahh...
        Now you've said there is no discernable movement between them can I also recommend FastStone http://www.faststone.org/FSViewerDetail.htm
        It's free for non commercial use and really cheap anyway for the quality of tool you get
        The batch processor is perfect for these types of jobs
        Decide how you want to crop using the crop board on onbe picture - note down the parameters
        Select all your files
        F3 to batch process
        Advanced - enter your crop parameters
        Put in your folder or rename parameters assuming you don't want to overwrite and hit go
        My places
        http://swga.org.uk/
          Re: Cropping query
          That sounds exactly what I want!! Thank you very much Andy - I'll let you know how I get on.
            Re: Cropping query
            Ahh...
            F3 to batch process
            Thanks for the tip regarding the Faststone program - it's great. Shows what you can learn when looking at forum posts in which you think you may not have an interest. I must find the time to read every one!
            Bob
            Bob
            To see what is in front of one's nose requires constant struggle.
            GEORGE ORWELL
              Re: Cropping query
              Ahh...
              F3 to batch process
              Finally got round to trying it out this morning - and it does exactly what I wanted, and quickly too. Many thanks for pointing me in the right direction, Andy.
                Re: Cropping query
                Is the Adobe Camera Raw built into Elements ? as you can apply a global change to a series of photos in there !
                E-M10 Mk2 - 14-42mm EZ - 40-150mm ED - Falcon 8mm Fisheye - FL-36R
                Wedding Photography Wales | Commercial Photography | Party Photographer Cardiff | Cheap Business Cards | Photoshop Training Cardiff
                  Re: Cropping query
                  Yes, it is - but I've only ever been able to open one image. How do you batch process in it?
                    Re: Cropping query
                    Drag and drop a pile of orf files to Elements and they should appear on the left of the ACR screen. You can select some or all of them and do what you want.. So far as I remember..
                    Pete
                      Re: Cropping query
                      Pete
                      Well blow me!! That works too - and I can specify the aspect ratio I need as well. Thanks Pete.
                        Re: Cropping query
                          Re: Cropping query
                          Cheers Steve - I'll have a good look at that when I get the chance
