A lot of software has as an option save with exif (or exif-jpeg etc), so it's worth exploring the options on the dialogues.
But Photomatix seems to lose a lot of the data (and The GIMP loses all processing Tiffs)
However you can just copy your edited image (probably as a layer) and drop it onto the original - provided you then save with an exif option then you'll have the original data.
Well I've done it - just take your final image and copy it (in the GIMP as a layer) across an original (probably the 0ev for HDR) - that gives you the originals exif.
Sure it could be used to cheat, but if you retain the orfs (camera jpgs etc) the trail is clear enough.
Exif is hardly secure data, it's just a field in a data file.
If you use a program, for example like Photoshop CS or photomatix, to create a HDR image how do retain the original Exif?
I seem to have problems even with just reducing images and retaining the exif. Does anyone know about this or can offer advice?
Graydon
Yes, I was struggling with exactly the same problem recently. I have just upgraded to CS3 (which I very reluctantly admit is worth the money...) and have therefore just started to play with HDR.
As you say, it does strip the exif, presumably because there are several exifs to choose from. So, as Nick suggests, load one of the original jpeg images, save the HDR jpeg as a layer on the top. Flatten it and in theory it should be the desired image but with the exif from one of the originals..
*Edit*
OK - I just tried this and it does work...
Pete
Reason: results of test
