Olympus cameras & an iMac computer
  • Olympus cameras & an iMac computer
    Hi anybody here using an Apple iMac computer to upload their photos?
    Please can somebody tell me how to stop the words "Olympus Cameras" from showing up in the properties field. When using Windows you can left click and go to remove properties and then choose which one to take out, this does not work with Apple. Any help would be welcome.
    Gareth Lovering
    I have over 14,000 photos and videos on line at
    http://www.facebook.com/Garethloveringphotography
    http://www.flickr.com/photos/swansealocalboy/
    http://www.youtube.com/user/garylovering/
    Re: Olympus cameras & an iMac computer
    What do you mean by Properties field - where and how do you see it??
      Hello Derek, many thanks for your reply. When using Windows you can left click and go to remove properties and then choose which one to take out, When I upload photos to Flickr with the iMac the words "Olympus Cameras" appear in the description field.
      Gareth Lovering
        From what I can see the Device Make is not editable from Finder.
        Dependant on what program you are using to create the image to go on Flickr you may be able to restrict the content of the EXIF data which is where the Olympus data is stored.
        In Photoshop one can do that - how are you editing your files 9ie which program are you using)
          I can't help with the question but I noticed this when I was uploading photos earlier, I am sure it didn't happen a couple of days ago when I uploaded.
          Good luck with finding an answer Gareth.
          The trouble with quotes on the internet is that you never know if they are genuine.......Abraham Lincoln
          https://www.flickr.com/photos/lexicon2011/
            I redefined your question to
            "EXIF editor for Mac" on Google and came up with a list of possible apps that will enable you to edit the data in the EXIF part of the file the first program was
            So I suggest you have a scan through the possible apps and try a few out.
            I also use Download.com to search for apps, they have a list of all apps for most platforms
              I think I have just done it using Photos which comes with Yosemite.
              Import the image and select it.
              Right click and choose 'Get Info'. The line OLYMPUS DIGITAL CAMERA should be visible.
              Select that and right click.
              Choose 'Cut' and the description should disappear.
              I don't use Flickr, so I don't know if it works but it looks as if it might.
                I use Photoshop elements 13 or Olympus viewer 3 to edit my photos Derek.
                Gareth Lovering
                  Thanks Olybirder I can see the information but not how to highlight I'm using Yosemite.
                  Gareth Lovering
                    Are you doing it in Photos? If so you should be able to click three times to highlight OLYMPUS DIGITAL CAMERA or alternatively you should be able to click at the start of the phrase and drag across to highlight it. You can't edit 'Get Info' working from the finder.
                      I use Photoshop for editing in the File menu choose File info this displays the metadata panel in the basic tab you will find the OLYMPUS DIGITAL CAMERA line click within it and change to to what you want ie OMD EM1. Click ok this is then saved to the metadata, you can also enter your name etc in another tab etc.
                      I find this quite an easy way to change things as I'm editing my files.
                      Hope this helps.
                      Tom
                      "Who is watching the Watchers, watching the Watchers watching us"
                      Its not what you see, it's the way that you see it"
                      Flickr http://www.flickr.com/photos/photofxstudios
                        Download Image Exif Editor by 扬超 张 on the App Store. See screenshots, ratings and reviews, user tips and more games like Image Exif Editor.
                        However I use Exifer. You can Export whatever info you want to a file, then simply edit the file (find & replace) then import the data back to the files.
                          Thanks Tom, that works now if I only do that to all the photos at once liked I could in Windows.
                          Gareth Lovering
                            Still can't seem to get it to work Ron will keep trying. Many thanks for your help.
                            Gareth Lovering
                              It will take some learning, but what about:
                              A command-line application and Perl library for reading and writing EXIF, GPS, IPTC, XMP, makernotes and other meta information in image, audio and video files. For Windows, MacOS, and Unix systems.
