All the text has turned to squares
  • HELP! All the text has turned to squares
    I was using my netbook a few hours ago and when I returned to the e system site after looking at another site all the text had turned to squares. I then looked at the four thirds site and the same thing happened there. This has only affected the two sites all other sites I have tried are fine.
    I have done a scan, no problems reported and rebooted the computer several times, still no luck. I am currently on my desktop which seems fine. There must be a setting I have inadevertantly changed, does anybody have any ideas?
    Thanks in advance
    Shirley
    Shirley
    www.shirleyhollisenterprises.co.uk
    www.photographsbyshirley.co.uk
    Re: All the text has turned to squares
    UPDATE
    I have just discovered that it ony happens when I use Internet Explorer, if I use Firefox all is fine!
    Shirley
      Sounds like a font incompatability problem.
      Some fonts have limited characters and if it is not loaded in a programme it just turns everything out as squares.
      Duncan
      Lots of toys.
        Originally posted by shirley View Post
        UPDATE
        Shirley - you don't say which version of IE you are using.
        Click the Tools button, and then click Internet Options. On the General tab, click Fonts.
        What do you see?
          Thanks in advance
          Shirley
          Hi Shirley - this is a bit worrying. I will investigate. I can't say that I can see the problem from here thought. But it worries me that you say it only affects two of our sites...
            What do you see?
            I was using IE8 but after I developed this problem I upgraded to IE9 thinking that might help, it didn't. I still have the problem on my netbook but at work and on my desktop all is fine so I really do not think it is a site problem, although it is only affecting the two 'e' sites.
            I am about to do a system restore so I will see if that works.
            Shirley
