Lightroom
  • Lightroom
    Does any body know how you switch to full screen view in lightroom
    reg
    Re: Lightroom
    Press 'f' which rotates through full screen, nearly full screen, and normal view.
      Re: Lightroom
      It changes the view slightly but i still don't get full screen view.
      reg
        Re: Lightroom
        You should do with that key press. What exactly are you after David...? What do you want to see full screen? LR or a single image...?
          Re: Lightroom
          A single image, when i used to use Elements 7 or 8 and you pressed f11 it gave you a total full screen view of just the picture.
          Many thanks
            Re: Lightroom
            Well you need to either press shift and tab, which removes all the editing/info panes, or move to the slideshow module and view the image as a single slide.
            Lightroom is not like Elements though, a totally different app.
