sigma 10-20mm instruction leaflet
Re: sigma 10-20mm instruction leaflet
As far as I can remember the instruction leaflet is very basic and certainly not worth buying, the lens on the other hand is mint
Just had a look in my 10-20mm box and I must have misplaced the instructions, oh well I did find a bit of paper saying the following.
WARNING
ABOUT THE FOUR THIRDS MOUNTH LENSES
* When selecting Auto Focus photography, it is necessary to set both the focus mode switch on the lens barrel to AF and your camera's focus mode switch to AF (s or C). If you wish to take picture in Manual focus, plase follow the same proveedure and set the focus mode switch on both lens and camera to MF.
* The function of AF-S mode with MF override is not available.
Info is very basic: usual warnings about damaging contacts and general handling. Use wide angle diffuser if using flash. Only use one filter at a time to avoid vignetting.
Do not turn focus ring manually while in AF mode or keep fingers on focus ring while autofocusing, otherwise mechanism can be damaged. As Garrie mentioned both camera and lens have to be in same mode AF+AF or M+M.
Same lack of information also available in ten other languages if needed.
Originally posted by Ken Lister View PostInfo is very basic: usual warnings about damaging contacts and general handling. Use wide angle diffuser if using flash. Only use one filter at a time to avoid vignetting.
The point about potentially damaging the mechanism is worth noting, and I hope any readers of this thread in the other languages agree!!Kevin
