I've just bought the Panny 100-300mm and the zoom is a bit "sticky". Zooming quickly to the extremes it's smooth as expected, but if you try and make small adjustments it kind of sticks and and then jumps making it almost impossible to 'finely' zoom. Is this is normal for this lens, and does it free up with use?
Panasonic 100-300mm sticky zoom
https://www.flickr.com/photos/99443690@N04/
www.tobygunneephotography.comTags: None
Re: Panasonic 100-300mm sticky zoom
Hi there Snerkler!
I have just bought one through the forum which is the same - checking online told me that this was a common "problem" but didn't come up with any solutions. I've tried a little silicon spray (on a cloth) rubbed on the barrel, but this didn't make any difference. Seems like there is too little lubricant internally, but I don't fancy opening it up to add more!
I'm hoping that it will loosen off in time, until then it doesn't bother me too much.
Cheers,
Ralph.
Thanks for this, as long as it's normal.Originally posted by Ralph Harwood View PostHi there Snerkler!
Cheers,
Ralph.Nikon Z7, 70-200mm f2.8 VRII, 18-35mm f3.5-4.5G, 24-70mm f4, 85m f1.8, 50mm f1.8, Nikon SB-700.
