I am thinking about getting the 70-300 and planning to use it for aircraft photography. So reading around the reviews which are generally very good I came across this one. Have a read of this, would like to discuss the cons and whether this is correct? What do you guys out there make of this? I will try and find the link again and post here.
Pros: This is one very good lens. This lens has the equivalent FIELD OF VIEW, not focal length (very big difference) of a 600 mm lens on a 35mm camera. The 2x crop factor is nice but this will NEVER fully replicate the image of a 600mm f5.6 on a 35mm camera make no mistake about this. I found the auto focus to be quite fast, I like it! The lens isn't that heavy so it's VERY good for bird photography. I like the AF/MF switch. The image quality is about the same as the 150mm ""kit"" lens but still, this kitten (as opposed to puppy) is a VERY fun lens to use! This thing has some gorillla reach. This lens is summed up with one word, ""unique"".
Cons: Believe it or not, the object in an image is exactly the same size as it would be if you used a 300mm lens on a 35mm camera. The Olympus DSLR's sensor is half the size so the angle of view is narrower than the same lens on a 35mm camera making it appear to be magnified but alas, it is not. It's like taking a picture with a 300mm lens on a 35mm camera and ""cropping"" the edges of the picture by 50% and expanding what's left over of the picture to fill the area that has been cropped out. The object in the image will just appear to be twice a large if you took the same picture with this lens! When I first found this out I was quite angry because of the ignorant wording used by 4/3rds supporters like ""600mm focal length equivalent"" is BS! When focusing from a close object to a far one, prepare yourself for some loud death noise from the motor. DOF is a lot larger as well with 4/3rds format. Some see this as an advantage, I on the other hand do not. No Nice blurry backgrounds @ F/5.6...
Other Thoughts: Do not fool yourself with Zuiko lenses! They are not nor will they ever be 2x the listed focal length. But also keep in mind that Zuiko glass is among the finest made right now if not the finest. The real advantage of the best Zuiko glass is that the F/2.8 lenses can be effectively used with 1.4 and 2.0 teleconverters without the loss of too much light by virtue of their insane brightness. I love my Zuiko 200mm F2.8/F3.5 so much I could spank babies with it.
However, as the resultant image is magnified more on a Four Thirds camera, any loss of focus is more noticable than it would be if using the same focal length on larger formats.
. I wonder is it's any different on the E-3.
