Warning: Undefined array key "birthday_search" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "joindate" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "posts" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "posts" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "userid" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "userid" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "privacy_options" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "userid" in phar://.../vb/vb.phar/library/user.php on line 2 Warning: Undefined array key "userid" in phar://.../vb/vb.phar/library/user.php on line 2 Warning: Undefined array key "lastactivity" in phar://.../vb/vb.phar/library/user.php on line 2 Warning: Trying to access array offset on value of type bool in .../vb5/route/profile.php on line 74 EZ v ED lens - Olympus UK E-System User Group
EZ v ED lens
  • HELP! EZ v ED lens
    I have had a faulty 50 -200 EZ lens recently replaced by Olympus but it has been replaced by an ED lens.
    The original lens was also a SWD but the replacement lens has no indication on it that it is SWD like my other SWD lens.
    Questions:
    What is the difference between an EZ lens and a ED lens?
    Does the 50 - 200 SWD lens normally have the SWD logo on it?
    Any input would be appreciated
    Re: EZ v ED lens
    Roy
    I may be wrong, but I believe all the 50-200 SWD lens has a blue ring around them close to the front element.
    I also understand the lens hood on the 50-200 SWD is different to the non-SWD version.
    Simon
      Re: EZ v ED lens
      it sounds like the replacement lens is the older non swd type..
      I don't own this lens but here is a pic of the newer swd 50 - 200 compared to the non swd 50 - 200.
      I hope this helps.
      Cheers
      Garrie
        Re: EZ v ED lens
        I've just taken this to provide a comparison between old and new:
        The new SWD model is on the left and the older version on the right.
        There is a gold SDW emblem on the new lens.
        Do you have a record of the serial number of your lens?
          Re: EZ v ED lens
          that would be the SWD emblem I take it......
          both are ED, in fact I suspect they both have the same glass elements, but if I had sent in an SWD I wouldn't be happy to get a non-SWD lens back!
          E, Pen and OM-D bodies
          43 m43 and legacy glass
            Re: EZ v ED lens
            I believe some optical changes were made with the SWD version, probably to accommodate the SWD ring motor. Just looking at the two lenses side by side you can see the internal details are slightly different sizes.
              Re: EZ v ED lens
              The use of the white text on the blue background showing the equivalent 35mm film focal length is rather tacky - it does not appear on lenses not supplied from the european Oly.
                Re: EZ v ED lens
                Didn't Roy ask what the differences were between EZ and ED, aren't they both SWD anyway?
                Further could someone tell me or point me in the right direction to what the EZ and ED acronyms stand for and what it all means I find it very confusing.
                Gavin
                  Re: EZ v ED lens
                  Originally posted by gno View Post
                  Didn't Roy ask what the differences was between EZ and ED, aren't they both SWD anyway?
                  Further could someone tell me or point me in the right direction to whatthe EZ and ED acronyms stand for and what it all means I find it very confusing.
                  Gavin
                  I don't think 'EZ' exists - I've not heard of this before.
                  ED stands for Extra low Dispersion, which is a high quality optical glass that helps keep the light focused tightly, even at full aperture. The 14-54 does not use ED glass and although it's excellent when stopped down a few clicks, it is relatively soft at full aperture compared to the 12-60 ED.
                    Re: EZ v ED lens
                    It's only a sticker and can be easily removed.
                      Re: EZ v ED lens
                      Thanks for the info on "ED" Ian.
                      Perhaps we need a sticky for acronyms and their meanings.
                      Does extra low dispersion glass generally give sharper images at the long end?
                      I'm still a bit confused about the two versions of the 50-200 mm lens do they both have the Supersonic Wave Drive or just the latest model?
                      Gavin
                        Re: EZ v ED lens
                        Gavin
                        The Mark II 50-200 was introduced specifically to feature SWD. Along with the 12-60, it was one of the first SWD AF leness to be produced by Olympus, and was launched with the E-3 at the end of 2007.
                          Re: EZ v ED lens
                          Gavin
                          Only the new Mk. II 50-200mm lens has SWD.
                          My Website
                          Workshop
                            Re: EZ v ED lens
                            Hi All
                            Thanks very much for the input, it is now very obvious from the posts that the lens I now have is a non SWD lens. Ian's picture has confirmed this.
                            The EZ issue looks like it could be a red herring, this information about the original lens came from a young lady at Olympus when I asked the question about the SWD lens, for which they did not have a answer.
                            The original (Faulty) lens was S/No 240019918
                            The replacement is S/No 060208998
                            I will have a word with Olympus on Monday!
                            Regards to all
                            Roy
                              Re: EZ v ED lens
                              If that is the case then
                              Surely Olympus would not replace a lens under warranty with an inferior model.
                              Gavin
