300mm f2.8 booked!
Re: 300mm f2.8 booked!
Well done Sir!
Well, it's big and heavy
Which body are you using? I recommend a tripod or a monopod.
If it's a very bright day and you want to use a wide aperture, the lens comes supplied with a drop-in set of ND filters.
IanFounder and editor of:
Are you sure of your working distance? If not, would the 90-250mm with 1.4 converter be more flexible? Just a thought.
I have no problem hand holding the E5/300mm at 800 ASA when photographing flying birds. IS is usually off. You do have to learn to zoom with your feet rather than a zoom ring! I've not tried much aircraft photography but for wildlife my 300mm gets far more use my 90-250 does. Whatever happens you'll soon realise you are using a stunning piece of kit. You also need to ensure you have the focus limiter set to the right range but for aircraft I imagine you'll want 6m to infinity.David
EM1ii, EM10ii
I have a tripod but think I will get a monopod that will go to my eye level for more flexability.Originally posted by Ian View PostWell done Sir!
Well, it's big and heavy Which body are you using? I recommend a tripod or a monopod.
The body is a E520. Not top of the range but it will have to do.
From reading up about shooting aircraft I need to centre the metering, centre the AF, switch of IS and get good at panning!
Having read up about shooting the jets at the loop a prime lens is prefered to a zoom as the prime can focus quicker. Also I want as much light coming into the camera as possible hence the f2.8 but if I put a converter on the zoom lens the min apperture value drops to around f4 I believe? That still may be fine but its all down to what the weather will be doing in the welsh valleys. The E520 noise levels above ISO-400 are quite noticible. I wont be able to shoot in burst mode with the noise filter switched on and will definatly need to shoot in bursts!Originally posted by Zuiko View PostAre you sure of your working distance? If not, would the 90-250mm with 1.4 converter be more flexible? Just a thought.
Thanks for reminding me about the focus limiter. Thats the next think I need to read up about. I'll see if there is a mannual for the lens to download but is it easy to set?Originally posted by Melaka View PostI have no problem hand holding the E5/300mm at 800 ASA when photographing flying birds. IS is usually off. You do have to learn to zoom with your feet rather than a zoom ring! I've not tried much aircraft photography but for wildlife my 300mm gets far more use my 90-250 does. Whatever happens you'll soon realise you are using a stunning piece of kit. You also need to ensure you have the focus limiter set to the right range but for aircraft I imagine you'll want 6m to infinity.
Oh and here are a couple of pics to give you an idea of the distance:
and if you want to see my shooting position ad what the background will be like then watch this video:
[ame]http://www.youtube.com/watch?v=3-7zHlOi4T4[/ame]
On Friday we had a Typhoon flying behind a Spitfire. I think it had some difficulty in going that slowly! Nonetheless it was making one hell of a noise and needless to say I didn't have a camera.David
EM1ii, EM10ii
Awesome! The typhoon is my favourite jet. In YouTube type in typhoon Mach loop. The sound it makes as it's approaching reminds me of airwolf! I bet the typhoon you saw was really struggling to go that slow. An unusual combination. Maybe they were practising for the jubilee fly past?
