Warning: Undefined array key "birthday_search" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "joindate" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "posts" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "posts" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "userid" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "userid" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "privacy_options" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "userid" in phar://.../vb/vb.phar/library/user.php on line 2 Warning: Undefined array key "userid" in phar://.../vb/vb.phar/library/user.php on line 2 Warning: Undefined array key "lastactivity" in phar://.../vb/vb.phar/library/user.php on line 2 Warning: Trying to access array offset on value of type bool in .../vb5/route/profile.php on line 74 F Stop Value - Olympus UK E-System User Group
F Stop Value
  • F Stop Value
    Hi All,
    Just a real quick question if you don't mind.
    Whats the oly F value Equivalent of Canon 400D F22?
    Cheers
    G
    Re: F Stop Value
    I maybe wrong, but I though the F value was for the amount of light let though the lens, so shouldn't it be the same?
      Re: F Stop Value
      sorry I meant aperture F value
        Re: F Stop Value
        The equivalent of f22 is f22. An f number is an f number no matter the system neg/sensor size or focal length. It is a ratio of the width of the aperture to the distance to the film/sensor plane.
        Ian C.
          Re: F Stop Value
          Garrie
          Are you asking about DOF???
          All the best
          Lots of cameras and lenses.
            Re: F Stop Value
            Hi Andy,
            Yeah I thats what I'm meaning, I'm rubbish at explaining stuff
            Cheers
              Re: F Stop Value
              Try these from Andrzej Wrotniak brilliant site.I believe DOF is greater for 4/3 cameras due to the smaller sensor.
              All the best
                Re: F Stop Value
                MINT - Cheers Andy
                  Re: F Stop Value
                  Please remember that from F5.6 onwards your lens will deliver softer and softer images - f/22 is to be avoided if at all possible. f/5.6-f/6.3 is the sweet spot for Four Thirds cameras. The softness as the aperture gets smaller is due to the effects of diffraction along the edges of the aperture blades at very small physical aperture sizes.
                    Re: F Stop Value
                    Thanks Ian - I didn't know that Maybe that's why I'm often disatisfied with the sharpness of my E-1?
                      Re: F Stop Value
                      Thats interesting, I have been led to believe the sweet spot on the 14-54 was nearer F16 before diffraction set in? Any landscape togs here wish to comment? Also does this differ with different lenses. I have had what I consider poor results on anything landscape wise where DOF was needed.
                        Re: F Stop Value
                        Here is a plot of the sharpness of a 50mm f/2 Digital Zuiko through its aperture range. The smaller the (DxO Blur Experience Unit or BXU the less blurred (more sharp) the lens is) :
                        There probably isn't a lens much sharper than this in Four Thirds and the edge/edge sharpness is very uniform, even at full aperture.
                        You can see that sharpness peaks at f/2.8 here, but f/16 is quite a way down.
                          Re: F Stop Value
                          E-1s, by default, have minimal sharpening set, so you should have plenty of sharpening latitude in post processing.
                            Re: F Stop Value
                            I hate using it though Ian - I know it's daft but still feels like cheating
                            I'd much rather get the basics right in camera if possible.
                            Do you have similar charts for the 35mm ZD and the 40 -150mm?
                            I'd love to know the optimum aperture for both of these too
                              Re: F Stop Value
                              Excellent post Ian, thanks, that is very interesting to see. Quite a difference from F11 onwards. This explains a few things about some of my pictures from the Lakes last year.
