E620 Menu
  • HELP! E620 Menu
    Can anyone please shed light on why when I press the menu button, I get the various camera settings lists as per setting and not the main menu itself? I'm beyond myself
    Thanks
    Re: E620 Menu
    Is this of any help to you?
    digital photography, digital camera, digital SLR, DSLR, E-1, E-330, E-400, E-500, E-410, E-510, Olympus E-Sysytem, Zuiko Digital, ZD lenses, Olympus Four Thirds, 4/3 system, E-series, E-System, E-system accessories, Four Thirds, ZD lens specifications, Olympus technical specifications, Zuiko Digital lens reviews, BIOFOS reviews, biofos reviews, John Foster lens reviews
      Re: E620 Menu
      http://biofos.com/esystem/e620_set.html
      Thanks but I can't display the menu at all.
        Re: E620 Menu
        If I then press the menu button again I see a different list of data.
        3 lists of data
        On the top left it says
        A, TTL, +/- 0.0, flash sign/FP, then flash sign
        B, OFF, -- (?)some symbol, then LO
        C OFF, -- , CH, then 1
        Then when I press the menu button again, it displays a black screen.
        Press again and it goes through the 3 sequences again, and again.
        Does anyone have any idea what the hell is going on??????
          Re: E620 Menu
          It looks like it's showing the menu for wireless flash control - go into the main menu and change the flash setting so it isn't acting as a master unit for controlling wireless and see if it helps. Haven't had a 620 for quite a while, but the E-PL2 menu system is almost identical....
            Re: E620 Menu
            Thanks Derek. Have you any idea how I can get into the main menu to do that?
              Re: E620 Menu
              Ah, just read your post again - this is happening when you try the menu button? No flash attached or pop up flash up?
              Very strange..... it might be a case of battery out overnight to see if it 'clears' itself unless anyone else can come up with an idea..... reseat lens; pop up flash if down; try combinations of two buttons, but failing all that, I'd say battery out and hope.....
              EDIT: Just tried my own camera in RC mode with pop up flash up, and get the flash control menu you're getting when pressing the 'OK' button, not the Menu button.
                Re: E620 Menu
                Thanks again. I'll put it to bed now.
                  Re: E620 Menu
                  Any luck with getting this fixed?
                    Re: E620 Menu
                    Hi Derek,
                    Got onto Olympus Techs, it's goosed apparently. So it's now off to get repaired.
                    Thanks
