I Need Help!
  • HELP! I Need Help!
        Re: I Need Help!
        If size matters and you want a small camera that you can easily take with you wherever you go the EP-1 is great, although it has some limitations (no view finder, slow autofocus). If you like your E600 and size isn't really an issue I would go for the E620. It is a very good camera, I owned one and only sold it to finance my E5.
        Some of my pictures can be viewed here.
          Re: I Need Help!
          I never understand this reasoning, unless you use a E-P1/2 with a pancake lens it's not pocket camera. And if you take a standard short zoom lens and a telephoto zoom with it for versatility then you will need a small camera bag.
          And if you have to take a small camera bag with you it's just as easy to put a two kit lens E-620 in it and with hardley any extra weight!
          Regards Paul.
            Re: I Need Help!
            Originally posted by Bovitz View Post
            ... the intermittent fault of stopping focusing, and needing to refit the lens to get it to work was a little worrying.
            Before changing cameras you should scrub the lens and body contacts with a pencil-eraser : it has sometimes cured the problem according to a few comments from t'internet.
              Re: I Need Help!
              The EP-1 with kit lens fits in my coat pocket. I also have a very small bag for it that I can comfortably hold in one hand or hang over my shoulder or attach to my belt without feeling any weight or being hindered by it's size.
              I can't do that with my E5 with 50-200 or 12-60.
                Re: I Need Help!
                True but your comparing a E-5 to a E-620 and the question is about a E-620.
                My twin lens E-620 kit fit in a bag no bigger than a ladies handbag and is no weight at all compared to my E-30 or E-1 kit which certainly would not get close to fitting in it.
                E-620 130x94x60cm 475gms
                E-P1 120x70x35cm 335gms
                Not a massive difference as we are talking centimetres.
                Regards Paul.
                  Re: I Need Help!
                  I've used them side by side and I found the difference big enough. The E620 package is more than twice the size! And double the weight if you count the lenses. I just mentioned the E5 because I don't have the E620 any more, but I don't think the E620 and the E5 differ much in size and weight.
                  I always have all my cameras ready to grab whenever I leave the house and my experience is that I often grab the EP-1 for convenience sake. In particular when I'm not going out on a planned photography expedition, but when I want to take a camera for just-in-case and you-never-know.
                  Just my experience.
                    Re: I Need Help!
                    ... but I don't think the E620 and the E5 differ much in size and weight.
                    You're talking rubbish.
                      Re: I Need Help!
                      E-3 with 14-42mm 1181g (in practice you would more likely use it with 14-54mm or 12-60mm)
                      E-520 with 14-42mm 850g
                      G1 with 14-45mm 685g
                      E-PL1 with 14-42mm 502g
                      There is about the same difference between the E-520 and E-3 as between the E-PL1 and the E-520.
                      The Pen is clearly much lighter than any other combination and much smaller when lined up on my desk. Whilst it is true that you still need a bag, it can be a much smaller bag - or just carry it around your neck all day.
                      Paired with the Panny 20mm the Pen does indeed become a pocket camera, not a trouser pocket but it does fit in a fleece jacket for instance.
                      The best choice is the one that suits your individual needs and best matches your priorities.
                        Re: I Need Help!
                        You posted quite something different at first I believe.
                        The E620 and the E5 both don't fit in my coat pocket (with a kit lens), the EP-1 does. That's my point, nothing else is very relevant in this discussion I think.
                          Re: I Need Help!
                          The joys of invisible moderation!
                            Re: I Need Help!
                            Just be aware that the Pens, and to some extent the Panny G series, aren't very good at action photos.
                              Re: I Need Help!
                              I didn't think it was that invisible.
                              No harm done, but passions can run high on internet forums and quickly escalate. We don't want this friendly forum turning into TP do we?
