Flash
Re: Flash
to turn off flash go into your flash mode setting and select the option with a circle and a flash in the middle that will turn it ofTo me, The goal is to move people, to make people think, but never, never at the expense of the person you're photographing. To laugh with, yes - but never to laugh at. - Lord Snowdon
Martyn
Olympus E30, HLD4 Grip E520 E300 HLD3 Grip, Pen E-PL1 Zuiko m14-42mm
Zuiko OM 28mm 2.8, 50mm 1.8 , 80-200mm
ZD 14-42mm, 14-45mm, 14-54mm, 40-150mm ,50-200mm , 70-300mm, 35mm Macro , EX-25
Sigma 50-500mm To be Obtained
Olympus FL36R ;Metz Flash 28AF-30
http://cannoncannonphotography.webs.com/
Re: Flash
Hi Chris.
You need to go to the "Super Control Panel" by pressing the Info button (Handbook p.7/p.28). Select the Flash settings icon. The section of the handbook which starts on p.66 explains what all the various flash modes do. You will want to select Flash Off
and when you do this the icon on the super control panel will turn to a flash symbol with a diagonal line through it.
Regards.
OM1n, OM 50mm f1.8.
Re: Flash
Hi Chris.
As you are new to the e-450 you will find Andrezej Wrotniak's site www.wrotniak.net useful.
His article on setting up the e-410/e510 is equally applicable to your e-450 and gives a much clearer explanation of what many of the settings actually achieve etc. than the Olympus handbook. This will give you a good starting point for getting the best from your camera.
The link to this article is www.wrotniak.net/photo/43/e510-sett.html
Regards.
OM1n, OM 50mm f1.8.
Re: Flash
Strange.
What comes up on the screen when you switch the camera on?Peter
OM1n, OM 50mm f1.8.
Re: Flash
Don't worry.
That's the super control panel.
Press the OK button in the middle of the arrow pad to the right of the screen and one of the boxes will turn yellow.Use the arrow pad to select the Flash symbol which is on the left below the ISO box. Press OK again and a row of options will be displayed, the Flash Off option is the right hand one on the top row. Use the arrow pad to highlight this option and press OK again. You should now have switched off the Flash.
Regards.Peter
OM1n, OM 50mm f1.8.
Re: Flash
My advice would be to leave the flash on Auto using the method described above by Peter and then go into the Menu system and find the Auto Pop up setting (see page 88 of your manual) and turn it to off. When you want the flash just press the button on the left shoulder to manually release the pop-up.
Re: Flash
To turn off the Auto Pop-up:
Press Menu
Press down arrow until Custom Menu E is highlighted
Press right arrow
Press down arrow to highlight Auto Pop-up
Press right arrow
Press up arrow to select off
Press OK
Press Menu to get back to the super control panel menu
Re: Flash
If the "menu" that comes up when you switch on looks like that on page 7 of the manual then you have the "Super Control Panel" and then the instructions in my last post should work.Originally posted by ChrisF View Postall these sound great but I just can't seem to get to the menus you guys talk about. and I can't make head nor tail of the manual
Don't give up we'll get you there.
OM1n, OM 50mm f1.8.
Re: Flash
Apologies I missed a step out, after pressing the menu button (2nd from bottom to left of screen) press the down arrow 3 times to get to the spanner 1 menu and then click the right arrow and the as stated before:
Press right arrow
Press right arrow
Press OK
