I've just been away for the weekend and experimented just using my EM10 with kit 14-42mm EZ (pancake) lens to see if it's good enough to use. Overall the combo is 'adequate' but some images were disappointing, and looked very blurred in certain areas of the frame but not others. See here, two different frames, both with the same 100 ISO, f5.6, 1/500 settings at 14mm (28mm eq), 100% crops.
This is taken from the top left corner, but not right in the corner
Note this is another 100% crop from the same frame as the first. OK, far from perfect, but better than the part of the frame in the first pic.
Also, look at this example. Note the blurred statue at the bottom compared to the sharper top of the frame (may need to view larger)
So what's going on? If it was shutter shock or camera shake I'd expect it across the frame. Also, I wouldn't expect camera shake at 1/500 with 14mm (28mm eq) focal length.
I've not noticed this before, but I've not really used this lens a lot before.
Otherwise, extremely weird!
