Sorry for the length of the post but there I was sitting back rather smug reading reports from others that their EVF had been damaged by sunlight shining through the viewfinder which was set at a high diopter setting, thinking it won't happen to me as I'm too careful. Sadly, last week I noticed the greenish yellow spots & streaks when looking through the EVF. This was despite not leaving the camera in the sun, always replacing it back in the bag after use and not having the diopter setting high. I have to say that the matter is being admirably dealt with by Olympus Service Plus and hope to get my camera back from them in a couple of days. They did send me an email which I think is worth sharing as their may be some owners not aware that there is a problem.
Dear Mr M
I am writing to you with reference to the repair of your OM-D E-M1 camera.
Please be advised that the large dimensions and magnification on the lens on the EVF can result in high concentrations of light (the gathering of light in a single point) when a strong light source hits the surface of the EVF. This physical effect will be particularly strong when the diopter is set to the "+" end of the scale. As a result the surface of the EVF can be damaged when hit by a strong beam of light, e.g. direct sunlight.
We have replaced the EVF this time, please kindly be careful when carrying it outside or leaving in the sun. When the diopter is set to "+" side, sun lights will be magnified on the surface of the EVF and it burns the material in case direct sun light is coming into EVF.The green spots are the burnt EVF surface, not defects coming from inside.
To avoid this, please kindly be careful not to expose the EVF under direct sunlight outside.It could help to set the diopter to "-" side when the camera is not used.
Your camera is currently waiting to be send back to you. I will email you the tracking information as soon as possible.
Should you require any further assistance, please do not hesitate to contact me and I will be happy to assist you further.
Kind regards
Edita Warlopova
Technical Care Specialist
Dear Mr M
Kind regards
Edita Warlopova
