E system flash & OMD-EM1
  • E system flash & OMD-EM1
    Working out what to flog to part fund the new camera body. Does the FL36 flash work with the OMD?
    Sylvatica
    Olympus E-30, 12-60mm SWD, 50 - 200mm SWD, Sigma 50 - 500mm, 9 - 18mm
    My web site: http://www.landscape-wildlife-photography.co.uk
    Re: E system flash & OMD-EM1
    Yes, the E-M1 is completely compatible with the Olympus flash system.
      Thanks, Ian.
      Sylvatica
        I'm not a great user of flash but do own an FL36 old version. I can't get it to work with my E-M1 in TTL mode only manual or auto.
        Am I missing something, anyone any ideas.
        All the best
        Lots of cameras and lenses.
          Hi Andy
          I assume you are referring to using the flash mounted on the camera? I have the FL36R and when mounted, pressing the "mode" button cycles through: "auto", "manual" and "TTL auto". Presumably this is not happening with you.
            Hi Andy
            Hi
            Yes with the flash mounted on the camera. I can only get auto and manual as if the flash is not talking to the camera(although the flash will fire). Hence the shutter speed is very low in poor light.
            I can put the camera into M mode and adjust the shutter speed to do what I want but that's messy.
            Ps the flash works fine in all modes on my E5 so it's not the unit.
            I'm stumpped.
            All the best
              Sussed it, I cleaned the contacts on top of the E-M1 and hey presto. I assume over the 10 months I've had it with the cover filed away in the box it's got some crap on it.
              All the best
                Hi again.
                Just looked on internet, someone had same problem but with panasonic camera and FL36, cleaned contacts with eraser, cured problem.
                Just a suggestion
                paul
                  Andy, you beat me to it.
                  Glad you solved problem
                  Pault
                    Hi Paul
                    See above, thanks anyway for the tip.
                    All the best
                      The other thing I've noticed is that the flash needs pushing fully forward on the hotshoe. Even just a shade out seems to make a difference.
