My first proper Pro-Capture play
  • My first proper Pro-Capture play
    Had it set on low,18fps,8 frames pre-release and 25 frames in total, still had a lot of culling to do.
    P6150045 by electric.mike, on Flickr
    P6150159 by electric.mike, on Flickr
    P6150319 by electric.mike, on Flickr
      Re: My first proper Pro-Capture play
      Cracking shots Mike!
      sigpicDave
        Great photos Mike!
        Larry Griffiths
        Lenses: Too many to list.
          Not what pro-capture was designed for i guess but tried it on a Greylag being chased by a Swan.
          Just a few of the 27 images i got as it ran past
          P6180059 by electric.mike, on Flickr
          P6180058 by electric.mike, on Flickr
          P6180057 by electric.mike, on Flickr
          P6180056 by electric.mike, on Flickr
          P6180053 by electric.mike, on Flickr
          P6180052 by electric.mike, on Flickr
            Still finding things to use this feature for, i focused on the bread and pressed the shutter as the fish took it.
            P6260054 by electric.mike, on Flickr
            P6260055 by electric.mike, on Flickr
            P6260056 by electric.mike, on Flickr
            P6260057 by electric.mike, on Flickr
            P6260058 by electric.mike, on Flickr
            P6260059 by electric.mike, on Flickr
                Great pictures. Pro capture is one the the main things (along with weather sealing) that I'd want to upgrade bodies for
                Junk on Flickr
                Even more Junk on Instagram
                  Great pictures, the pigeon is to die for.
                  I'm just wondering where P-C fits in vs conventional C-AF ?
                  As an aside Mike, would you mind sharing with us your PP secrets for producing such wonderfully sharp web images.
                  TIA
                    TIA
                    Thanks for the kind words Dave, i think the PC fits in when say a bird is flying towards you, by the time you get focus press the button and the shutter fires the bird is no longer in the same place, PC gives you a selection of shots from before during and after you pressed the button.
                    The same principle would apply to the fish, with the goose it wasnt needed unless you want 18 fps.
                    Not sure what to say about the PP, i use a very basic workflow, raw goes into ACR i click auto and see what it gives me, if i like it i take the image in to photo shop if i don't i click auto off and then go into photo shop.
                    In photshop i some times lift the shadows and then adjust the curves, i mainly save to 1024 for web, that can give a false impression of sharpness.
                    Some times i give them about 15/20% unsharp mask but if i am doing that i select the subject and only give it to the subject,i may then (like the top pigeon) invert the selection and apply noise reduction to the background, or lens blur.
                    I never use noise reduction on the main subject and the only sharpening i give is the preset 21% in ACR and a possible unsharp mask,then when ime resizeing the file i use bicubic sharper.
                      This may be the wrong descision but looking at my results i think i am going to reduce the frames if i can to 5 pre and 5 post
                        I think the number of shots stored prior to fully pressing the shutter is a function of how quick your year reactions are, for me I need to store as many if not before "exposure" as I store after exposure.
                            As i see it from the moment you press to focus you are filming in raw, yes pressing the shutter stores the predetermined amount of shots and this is best set to fit how quick your reractions are.
                            I want to get it to the least possible so i can use it more often, what i find can be a problem is while waiting for something to happen i see a single shot i want,if i start changing settings i would miss it but i don't want 25 shots of a posing blackbird as above.
                              Another go at fish, one burst of shots again.
                              P7190272 by electric.mike, on Flickr
                              P7190273 by electric.mike, on Flickr
                              P7190274 by electric.mike, on Flickr
                              P7190275 by electric.mike, on Flickr
