High Res shot and studio flash - not working on EM1 Mk2
  • High Res shot and studio flash - not working on EM1 Mk2
    I'm having problems triggering studio flash in high res mode on the EM1 Mk2. I have no issues at all using an EM5 Mk2. I also have no issues triggering the lights in single shot mode (with the EM1 mk2)
    My settings are 30sec delay and 2 sec charge time.
    Anyone else having this issue or able to help please?
    Thanks in advance
    Re: High Res shot and studio flash - not working on EM1 Mk2
    I posted this on DP Review and someone else responded and is having the same problem. It would be appreciated if any EM1 Mk2 owners out there could try any flash, hot shoe mounted or studio lights, in high res mode and report back
    Thanks again.
      I noticed the other day that flash doesn't work with the the electronic shutter.
      I've not played with the high res mode as yet but assume it uses the electronic shutter.
      May be I have a setting wrong for flash but I'm not a great flash user.
      All the best
      Lots of cameras and lenses.
        I'm a bit confused with the EM1 Mk2 menu, as the anti shock option has been removed. Now only have the silent shooting option, which is known to disable flash.
        I feel like packing the camera up and sending it back to be honest. If this is a bug, I'm flabbergasted that a flagship model, aimed at professionals, has been released without testing. After all, the high res mode is advertised as being perfect for product photography in the studio!
          Have you looked "gear"-"D1"-"Settings" you might be able to turn "anti0shock" on
            Thanks Paul, only had the camera for a few days and been working through the manual and hadn't realised that certain options can be hidden.
            Is the anti shock option using the electronic shutter?
            I know that the silent mode uses electronic shutter and cannot be used with flash.
              As I know Anti-shock uses mechanical shutter
                That would explain why I can use flash with anti shock shutter.
                  You can set flash for use with silent shutter, but it is set to off by default. Just enable it in the menu.
                  Stuff from Cuba
                  More stuff from Cuba
                  It all started here
                    Thanks, for a minute wondered if that might have solved the flash not working in high res mode but alas, it still won't fire.
                      Have you checked:
                      "Camera settings limitations: shutter speed not longer than 8 sec, aperture not narrower than F8, ISO not higher than 1600 and flash sync not faster than 1/50sec (previously in E-M5 Mark II or PEN-F, flash sync limit was 1/20sec)"
                        Thanks Graham but everything is set correctly (as far as I know). Shutter speed 1/50th (have tried with 1/20th too), ISO 200 and f5.6. The high res shot actually completes, but it won't trigger the flash. I've even tried the little Olympus flash on the hot shoe and it won't fire. Flash fires fine in single shot mode.
                        This really has me beat.
                          Does the flash fire in high speed silent mode?
                          Stuff from Cuba
                          It all started here
                            Just checked that and no it doesn't fire the flash in high speed silent.
                            What significance would that have?
                              Is there a setting for flash in both H and L modes? Don't have the camera with me so I can't check.
                              Stuff from Cuba
                              It all started here
