Hi,
I don't currently have a camera, but my friends looking to sell his e500 and I was wondering if anybody had any feedback on them before I consider buying it.
Read this article from J. Andrzej Wrotniak it tells you everything you need to know about the camera. But bear in mind it was written in 2005 so things have obviously changed a bit since then. It was my first DSLR and I thoroughly enjoyed using it.
Action sports aren't exactly Olympus' strong suit, though the skill of the photographer can overcome many technical limitations. For hand held work, a body with stabilization (510 onward) might give an advantage over the 500.
Yes, the 40-150 is a good place to start.
I hope it is not too forward in me highlighting I have just listed a 55-200mm for sale on the forum.
For sports you may want good performance at high shutter speeds which means you may need to use high ISO and work with small f numbers.
You really do get what you pay for - as I am finding out everytime I get a lens I want the next one up.
Personally I think the E500 would be an excellent starting point as it will be a very cost effective way of getting results. The draw back for some is this camera is only 8Mpixels, but that is not going to limit you IMO.
I'll let others comment on how the sigma 55-200mm will compare to an olympus 40-150mm, a possible advantage is that the 55-200mm has a little more reach at the same f number.
Do you think the image stabilisation is going to come into play and benefit for sports photography?
I woudl have thought that shutter speeds would generally be high enough to render the IS pointless??
Sports photography isn't one of my strong suits either, not at all. So perhaps the IS would not be of use at higher shutter speeds. The question of which camera is best for sports is outside of my experience (I feel confident I could adequately capture the action in a spirited game of chess, perhaps), but if I were going to give it a go, I'd pair an E-1 with a 50-200 mkI and see what happens. The E-1 has a decently fast shutter, and unlike other used Oly bodies in its price range, has a twelve shot buffer. ISO 800 is quite useable (to me, anyway), and if "sports" equates to "weather," it's good for that, too. Is also a rig that if it didn't prove up to the job, could probably be resold without much loss.
But really, any used body and zoom (such as Richard offers) would be a good place to start.
