I have a macbook air, which is fine, but does not have a lot of memory, so I use an external SSD when on hols to store my images. I keep getting message, 'your start up disc is low on space, please delete some files". Not exact but you get the point. I have removed PS 5 and other aps but wondered if I could get a bigger internal drive.
Any had this problem and been able to sort it?
You can upgrade the internal SSD drive. OWC have the hardware and installation videos, and the procedure looks fairly simple.
My wife has a MacBookAir, and has the same problem as you, and when I get a chance I will do an upgrade for her.
OWC i think is Other World Computing inc, another is Crucial, I think in Uk. I used them to upgrade to SSD ON my Macbook Pro a few years ago. Before you install the new drive you have to install a mirror image on the new drive via USB connection. Iused a program “superduper” my create a bootable image.
Have you put a micro SD card into the SD slot there's a special holder available for permanent use, then you can move stuff from your start up disk to the micro sd card... I have my Apple Photos and my iTunes stuff on one.
[QUOTE=Walti;480386]Have you put a micro SD card into the SD slot there's a special holder available for permanent use, then you can move stuff from your start up disk to the micro sd card... I have my Apple Photos and my iTunes stuff on one.
I think the MacBook Air still had the SD reader until the very latest upgrade when they added the retina screen and took away everything else useful. The MacBook has never had any proper ports at all, just a single USB-C I think. Madness.
It's the other way round. My MacBook has all the ports, but my wife's MacBook Air has only the USB port.
