Hi if the card is fully dried out give its go, it should be ok I have done a similar thing in the past and worked never had a problem with it, you wouldn,'t harm your camera, if in drought put it in a card reader and insert it into your computer and try to save a image to it, if its damaged at all it will not be recognised by the computer.
I've no experience of this so can't really say, but personally for the cost of a card I don't think I'd risk a malfunction. That's one of the reasons I use several 4gb cards rather than a big expensive one.
No, he's got the opposite problem, Dave - more like a flood!
It's not simply the case that the card's electronics are dry. Although I'm not sure what chemicals make up washing up liquid, there's a fair chance that some are ionic in nature and the residue inside effectively become part of the circuit, causing things to happen inadvertently. Even capacitive effects alone would allow charge transfer. (By design the switching elements within the 'card' are metal oxide, and it's the capacitive effect that is used to affect switching.
If you really want to have a go at this, wash the card repeatedly in distilled water, rinsing many times, then let it dry.
I would only do this if a) I was bored and wanted something to do, or b) it was the last memory card on planet earth.
Good luck.
