Wireless remote flash?
  • Wireless remote flash?
    Hi guys,
    I have an E-400 and a FS FL-36 flash, I'm after a wireless remote flash that will work with my set up..
    I came across this
    amazon.co.uk/Channel-Wireless-Trigger-Umbrella-Flashgun/dp/B004LP6JFU/ref=sr_1_2?s=electronics&ie=UTF8&qid=1342700179&sr =1-2
    (can't add links yet)
    Will it work /any good?
    Maybe get my self a umbrella or soft box too at some point..
    Shane
    Re: Wireless remote flash?
    Hi Shane
    These are the ones you need. I have a set of 3 receivers and two triggers.
    I bought them from this chap but from his eBay site rather than the one I linked to here. Very helpful, and they work a treat.
      Yes, I use iShoot triggers as well (previous version) and they are generally OK. A Whole Lot Cheaper than Pocket Wizards..
      Pete
        I've got some from Phottix which are simple and seem to work well. No TTL auto flash control, but I reckon that's over-rated anyway.
        Ciao ... John
          I use these, the advantage being that you can control the camera with them as well as the flash
            Many thanks guys think I will go with the ishoot model ..
            Shane
              Just a quick question . will the receiver fit on a tripod or will i need a light stand and special fitting etc?
              cheers
                cheers
                Shane - the iShoot receivers have a standard tripod screw mount (female thread) on the underside so you can attach it to a stand and place the flash unit on top.
                  excellent thanks i have ordered one tonight
                    Hey guys
                    Just received my ishoot.. Put some Batts in and connected it to Flashgun but it won't trigger the flash.. Even if I press the button on the remote ?
                    Didn't come with any instructions.. Red light come on the remote when I press the button and on the receiver there is one flashing red light?
                    Any ideas
                      Have you swiched the channels on the receiver and the transmitter to operate on the same channel? Easily overlooked.
                      Benedict
                      People may not remember exactly what you did, or what you said, but they will always remember how you made them feel.
                        Yes, I tried all different incase there was interferance. I bought new recharchables so maybe not enough power in them.. Also I have another flash at home could try that too..
                          Any ideas
                          I have heard this happens with those and that the item is essentially DoA
                          I've not heard a bad word for these:
                          Send them back and get something that works.
                          Good luck
                            It does sound as though you have a dud, Shane. I have three receivers, and two triggers and haven't had any issue with them over nearly 3 years.
                            If, when you press the button on the top of the transmitter, there is a flash on one of the LED's on the receiver - they the comms between them seems to be working. If though, when you place the flash on the receiver it doesn't trigger the flash then there's something amiss. Perhaps as a last resort, clean the flash contacts (after turning the power off) and also the trigger contact on the receiver and see if that works.
                            Sorry you're experiencing issues after I recommended them.
                              hi john.
                              after alit of button pressing battery changing channel hopping and sulking.. it fired.. i worked out it will fire id the two units are touching .. if i move them apart even 1cm it wont. i emailed uk highlander.. he emailed my back in about a 1min 30secs .. anyway he asked what batts i was using and said its made to take 1.5v aaa i was using 1.2v so i went and got some more news batts this time 1.5v but it does the same its like it goes out of range.. anyway i told the guy at uk highlander and he asked what flash i using.. awaiting reply. and dont worry john im sure its just a dud..
                              shane
