I was playing about today using a slave flash to even out the lighting on some stuff I am selling on ebay.
The slave flash has a power selector that is calibrated in f stops. When I select f11 on the slave (the most power?) the slave doesn't fire. It will only fire at f5.6 and below. I am testing if it fires by pointing the slave towards the camera, when it fires then it is pretty obvious.
I'm using an E520 and FL50 and have tried changing the shutter speed as low as 1/60th just in case the slave is actually firing but after the shutter has closed. I would have thought that the lower the power on the strobe then the shorter the flash so the more powerful setting should show up more.
I have also tried both modes on the slave just to eliminate any pre-flashes spuriously triggering it.
Any ideas on what else i could try?
Roy
Roy
