IBIS on monopod
  • IBIS on monopod
    Do you normally turn off IBIS when the camera is mounted on a monopod? I believe IBIS has to be turned off when using a tripod.
    Re: IBIS on monopod
    EDITED
    You could use IS3 for horizontal shake only, but there be may some vertical as well so maybe leave it on anyhow. It depends how the photos turn out. Check for vertical blur with it on & if it's there then try IS3 instead as it could be over compensating.
      Re: IBIS on monopod
      As there will still be some movement when using a monopod, I think that the answer is to keep IS turned on.
        Re: IBIS on monopod
        I agree with Dave. I've tried IS1, 3 and Off mainly in motorsports with the E-M1 and the 100-300 and 40-150 kit and Pro, and I can't see a consistent difference, so I leave it at IS1 so I don't forget to turn it back on
          Re: IBIS on monopod
          Thanks. I will keep IS 1 turned on as recommended by Dave. In his Guide Book, Gary Friedman mentioned that IS 2, IS 3 & IS Auto are used for panning.
            Re: IBIS on monopod
            Actually I think it depends pretty much entirley on subject.
            If subject is static then I have IBIS on, unless shutter speed is faster than about 1/1000 sec.
            If subject is moving then I sent IBIS off.
            Gary
              Re: IBIS on monopod
              The function of IS is to compensate for camera shake. I don't see how it can cater for subject movement. The subject can only be "frozen" by high shutter speed which itself would take care of camera shake.
              Zul
                Re: IBIS on monopod
                I suspect Gary is referring to whether you're panning or not rather than on whether its a subject that's moving in the frame.
                  Re: IBIS on monopod
                  Hi, ZulSim. First and foremost, welcome to the forum.
                  The rules are, there are no rules but the ones that actually work for you.
                  The advantage with digital is that you are now able to push the envelope more.
                  When much younger and, with enough care, I could on many an occasion get good shots as slow as 1/20 hand held.
                  Over the years, that crept up to 1/1000 and is still climbing.
                  Just remember, each and every situation is borderline. We each need to test ourselves to find personal limits where slow speed movement becomes an issue
                    Re: IBIS on monopod
                    +1, been doing it for years.
