omd em1 mk2 card viewing problem
  • omd em1 mk2 card viewing problem
    is there a quick method of viewing either card position pictures without going into menu,help required as I cant find one yet.
    Re: omd em1 mk2 card viewing problem
    Press and hold the blue "play" button and rotate the front dial, an icon comes up showing the current card being viewed rotate it again and it'll change.
    I had to ask Olympus at one of their events, how to do it as I couldn't find it in the manual and the guy I asked didn't know and had to disappear to find out!
      it works! must av spent at least an hour trying, thanks a lot, the forum rules again.
        That was something I had to work out in the beginning, but it actually does have it mentioned in the manual on page 78.
        Tips
        To change the playback card, while pressing the [>] Play Back button, turn the dial to select a slot, then release the [>] Play Back button.
          thanks ross,I play rather than read,gets me in bother often. I,ve gone dual card since I got pro capture on the last update so I have a fast card for it, been using it today on sand & house martins bifs.
            Yes, the ProCapture saves quicker on the UHS-II SD card & that's how I have mine set up too. I send the video to the slower UHS-I as it is just fine for that (when I actually take any video).
