How to snap a Mongoose at night without a flash?
  • How to snap a Mongoose at night without a flash?
    All the best
    Phil
    Re: How to snap a Mongoose at night without a flash?
    It's most unlikely that the flash will scare the Mongoose although it it's any significant away getting the flash to throw that far will be challenging.
    Best wishes
    Wildwood
      Thank you for helping. I did a test shot from the bedroom window with the flash on using a phone. In the photo to the right of the illuminated pool, the Mongoose hunts the bushes. Sometimes there are two Honey tailed Mongooses and it would be nice to be able to capture a shot of them. My apologies for the very poor quality of the photo and the noise.
      All the best
      Phil
        What lens do you have on and why f4.1?
        Why not try a shot in the night with the biggest aperture with and without the flash.
          All the best
          Phil
            Not sure I'd want to point the flash directly at the Mongoose (at least not if the Mongoose could get at me - I hear they're vicious little buggers), so yes you would need something to bounce the flash off. Also.... depending on the size of the area a higher guide number (wouldn't fancy the chances of my FL-36).
              Hi Phil. I have found that video is good for low lighting photography. But there has to be some light of course for focus etc. My other suggestion is to use a Trail camera. They put out an infra-red or UV (I think) light to light up the scene. They can work in still photo mode and /or video. They work well for my hedgehog stuff. Alas I only have video of him so cannot show you a piccie. Downside is that the photos and black and white, unless there is reasonable light around...….
                It's been a while since I have done any flash photography. SO I could be wrong.
                Some flash expert pls advice. on my assumption.
                If the base iso setting is 200, the flash is at full power the distant from the subject is say 20 feet, If the ISO is set to 400, the flash can be reduced to 1/2 power if the subject remains at 20 feet.
                If the reach is required, say 40 feet the ISO remains at 400 but the flash need to be increase back to full to achieve the correct exposure.
                So if the distant is now 80 feet, can the ISO be assumed to be increased to 800?
                I am only assuming that the Aperture and Shutter speed remains the same.
                  Hi, thanks for thinking about my question. When the Mongoose stands on its hind feet, it is quite intimidating, so I am happy not to get too close even though they are cute to look at and what you have said about them being vicious is very helpful. I think there must be a family of them living not far away. I have not found where they go to during the day, but I have seen different ones come up to the house after dark between 1 - 5 a.m, they look well fed, not scrawny. I tend not to go outside of the house at night because of the predators, but I might have to make an effort in order to get the shot
                  Here is a view from the bedroom window looking down over the bushes and towards the forest. I have seen the Mongoose go to the salt water pool and drink from it.
                  The flash I have got is called an Olympus FL-LM2, it has never been used
                  Pool view from bedroom by philip Gate Keeper, on Flickr
                  view of Agapanthus beds from bedroom by philip Gate Keeper, on Flickr
                  view from bedroom towards the forest by philip Gate Keeper, on Flickr
                  All the best
                  Phil
                    Thanks for coming back and giving me the settings for shooting in the dark. I have never taken any photos in the dark using an Olympus camera with a flash. Your settings I will try with the flash. Thank you very much.
                    All the best
                    Phil
                      Hi Mark, thanks for the advice. I had not thought about using a video. I have a Sony Video which has a night shot facility where everything comes out in black n white because of the IR. I was hoping to use an Olympus brand, but what I have is fairly limited. I am flying to the UK in 2 weeks time for 3 - 4 months and could look out for a trail camera, is there one you can suggest? We have not seen any dangerous snakes up at the house for several months and I think its because the Mongooses are eating them or scaring the snakes away. You have lived in Africa and your insights are appreciated. Thank you very much.
                      All the best
                      Phil
                        The Mongoose isn't going to attack you unless you corner it and try to grab it. If it senses you're there it'll run away.
                        Photographing animals in the dark can be rather challenging. Even if you have a powerful enough flash you have the problem of how to focus the camera. Many years ago, before I located their sett, I used to photograph Badgers in the dark. The method I used was to put down a handful of peanuts then focus the camera on that spot whilst I still had light. It was then a matter of waiting, often for hours, for a Badger to come along and find the peanuts.
                        But without a decent flash that option probably won't work for you. What you could try is to set the camera up outside with a wide-angle lens set to manual focus and use hyperfocal focusing to set a really deep depth of field. Then trigger the camera from a distance using OI Share if/when the Mongoose moves into the in-focus area.
                        Best wishes
                        Wildwood
                          Could you run a mains cable from a plug in dimmer to a tungsten bulb near to where they will be? That way you could build up some illumination without startling them. Or maybe put a battery operated PIR light down there that will trigger when they are in the area. They will soon get used to it.
                            You could try a test shot of the approximate area you want to photograph. See the results. Another thing, try that IR focus assist if you are using the Oly's flash but turn off that strobe. Does that RED focus light still available on the newer flash?
                              https://www.ukwildlifecameras.co.uk/...eras_C135.html
                              Phil, I bought a Browning Trail Camera (not a gun!!) off these people in the link above.
                              They have a super range of Trail cameras to suit your pocket and circumstances. I can recommend them...………
                              A photo taken off a video shows the quality...……..
