W10 Update Slowed PS CS6 Launch
  • W10 Update Slowed PS CS6 Launch
    A few days ago there was a Windows 10 update. Among the things it sorted was the recent tendency for "Shutdown" to default to "Switch user".
    I thought it more than coincidence that, after the update, my PS took about a minute and a half to launch. It had never been quick but that was ridiculous.
    For a while I wondered about a recent reinstall of a plug-in.
    Anyway, yesterday a further update got PS but to its former launch speed.
    Harold
    Re: W10 Update Slowed PS CS6 Launch
    Just as a note on Win10 shutdown
    When you use Shut Down it uses a variant of the sleep/hibernate process to push as much of what is in memory as possible to allow a faster boot
    if you want a clean refresh of the drivers in memory etc then restart is a better option as it clears those out
    The delays could have been some old driver in memory which was cleared out when the further patch did a proper full restart
    if you see slowness at start it's always worth a proper restart which is different thinking than prior versions of windows
    My Kit (OK I'm a hoarder...)
    My places
      Thanks, Andy.
      I agree with the fresh restart when the start-up is taking a long time. It works every time.
      Harold
        +1 to Andy. Also, there is a "Fast Startup" option which is best turned off. I find my video driver doesn't always work properly if this is enabled.
        Go to Settings > Power and Sleep and scroll down to "Additional power settings". Click on that and then "Choose what the power buttons do". Now click on "Change settings that are currently unavailable" and untick the "Turn on Fast Startup" box.
        I find with that box ticked the machine does start up more quickly but it also takes longer to shut down so it's as broad as it's long, but it does ensure that all drivers are properly loaded.
        On another subject yesterday's update has once again reset my graphics files association to the horrid Photos app so I've changed them back to the old Windows Photo Viewer which is much faster. The way MS keeps doing this drives me nuts!
        Richard
          I still found it slow, taking over a minute to launch.
          I suspected some crud in the system was slowing it.
          I installed CC Cleaner free version and ran it. PS now launches in less than 15 seconds.
          Harold
            CC Cleaner has also sped up FastStone Image Viewer.
            Harold
              Harold
                Mine has been the same time, irrespective of reboot or relaunch.
                Harold
