Windows Problem
  • HELP! Windows Problem
    Following the latest Windows update yesterday I keep geeting a pop up message informing me that the "Synchronization Application stopped working and was closed."
    The message continues....."A problem caused the application to stop working correctly. Windows will notify you if a solution is available."
    Apart from the message, I haven't noticed any problems (that I don't already have) with the computer. Does anyone know what this means and should I be worried/take action? I have Vista.
    Thank you.
    Re: Windows Problem
    John, nothing to worry about, but Vista is notorious for stuff like this - if it persists and really bothers you just roll back the updates. I never used windows update with Vista due to problems like this, so when I got to the point where everything was working OK, I just disabled it. I would was say a case of it's not broken, why fix it, but Vista is basically broken from a fresh install anyway!!
    Edit: Is this only happening when you boot up, or popping up randomly?
      Re: Windows Problem
      Thanks Derek, if it's not anything to worry about I can live with it. I think it does only happen when I boot up, or shortly afterwards. I've always thought it best to accept the updates but now I'm not sure -as you say the program is basically flawed anyway!
        Re: Windows Problem
        I don't worry when I get a pop-up like this, just say "P**s off" and close it!.
          Re: Windows Problem
          Thank you.
          Mine's doing the same. I expect they'll fix it with the next update.
          OM1n, OM 50mm f1.8.
            Re: Windows Problem
            Or make it worse!
            Sorry you are having the same problem, Peter, but it is somehow reassuring!
