Olympus 1.4 mc 14
  • Olympus 1.4 mc 14
    http://www.wingsofnature.org
    Re: Olympus 1.4 mc 14
    Apparently a common problem, I had mine loosen off and caught them before I lost one, but it was close...
    Edit: If you're going to the Photography show, the repair/cleaning service may be able to help you!
      Just checked mine and they are all nice and tight. Perhaps they forgot to put some lock tight on the threads when they were assembling a batch.
        Not sure exactly what you need to replace - I had a couple of tiny screws disappear from my laptop. I hunted in vain for the specific ones I needed but ended up buying a job lot of all sorts from eBay.
        If you search for Laptop screws you'll find lots of listings.
        If you have a specific size e.g M2 x 4mm I'd be happy to trawl through and see if I can help.
          Thanks for the idea but alas decided not to go I case I submit to the new x
          Kind regards mike
              Just a thought, if the screws are tiny ... would something from an old pair of glasses fit?
              You could also look at any number of other items to see if you can 'borrow' a screw which would not be missed like one holding a circuit board in place or from any other electrical item.
              edit to say ... Make sure the thread is right, you could take one out of the MC14 to try carefully in the hole you took the trial screw from so you are not in danger of messing the thread on the MC14.
                It does seem to be a strangely common problem. This link is to a blog by Panasonic Luminary Daniel J Cox who had the problem with his MC-14 (scroll down to the section on the 300mm f4). Not unsurprisingly it has affected his opinion of Olympus' build quality ever since.
                I must check mine sometime and I hope you manage to get your problem solved without too much expense Mike.
                  Historically, the Japanese camera industry used JIS (Japanese Industry Standard) screws. However, I have removed one screw from my own MC14 and the thread seems to match metric ISO M2. Unfortunately, there is a snag. The screws used in lenses always seem to have very small heads and the heads on standard M2 are too big to fit into the countersinking on the MC14 flange. I found one screw in my box that seemed to fit but that was a slotted head countersunk screw not cross headed.
                          Whenever an item of camera gear I have dies, I always keep as many of the tiny screws as I can recover. Goodness knows why but I have been doing this for years and have loads of them.
                            Originally posted by Mdb2 View Post
                            Their excuse that my mc14 was not a lens, or camera, so wasn’t covered by my Olympus pro cover warranty. I am tempted to send them the link you gave me.
                            You should be able to find a few more links as I've seen this fault reported a few times before. I would send them the links and point out that as you are paying for Pro cover they should deal with this as a known fault. All you are asking for is a checkup and 1 screw!
                            Found another link:
                            https://www.mu-43.com/threads/odd-e-...d-mc-14.89780/
                            bengeo.com
                              If the replacement screw is too long, don't forget to put a nut on it before you cut it down, chamfer and deburr it.
