Oly 300 f4 spoiler?
  • #16
    Re: Oly 300 f4 spoiler?
    Obviously the panaleica is vapour wear as it is just an intention to develop it, the point was the timing of the announcement! It seems more like a Nikon / Canon trick?
    Have they ever failed to produce a lens that they announced like this?
    • #17
      Yea, but at 300mm, the 100-400 will be f5.6 or thereabouts.
      Originally posted by Alpha1 View Post
      So will the F4/300 with the 1.4 converter attached.
      Paul was comparing max aperture at 300mm.
      At 300mm the Oly F4/300 will be F4! (no TC required)
      • #18
        vapourware
        ˈveɪpəwɛː/
        noun
        COMPUTINGinformal
        software or hardware that has been advertised but is not yet available to buy, either because it is only a concept or because it is still being written or designed.
        Stuff from Cuba
        More stuff from Cuba
        It all started here
        • #19
          f/5.6 @ 420 mm
          f/4.0 @ 300 mm sans TC
          Regards Huw
          Olympus equipment
          Capture One Pro
          My flickr
          • #20
            Sorry forgot the happy smiley , just the definition does not mean they won't make it, just purchasers of the 300f4 May wait a little longer. . . .
            Stuff from Cuba
            It all started here
            • #21
              I am sure the Panasonic Leica lens will be excellent but a) it's a zoom (so the optical design is more of a compromise) and b) as previously mentioned, it will be slower (less bright) at 300mm. It will probably be larger and heavier, too. There is plenty of room for both of these lenses in the Micro Four Thirds armoury
              From a wildlife photography point of view a zoom is much more useful than a prime as the size and distance of a subject cannot be predicted and is more often than not a very brief affair. In this context changing lenses is not practical so a zoom is quite likely to be the only way to get the shot you want.
              • #22
                I totally agree David. In fact I use two e-M1 bodies, one fitted with a wider zoom lens and the other with a long zoom lens. It is surprising how often I have to drop one camera to use the other to shoot at a closer range. I never use primes for shooting wildlife.
                • #23
                  Another advantage of a zoom is it is easier to find the subject zoomed out, then zoom in to take the shot. I hace used a long prime for birds and if the bird is in a bush it can be very hard to find it before the bird has flown away.
                  • #24
                    It looks like it's going to happen and Spring 2016 seems to be a favourite launch date.
                    New LEICA DG 200-800mm (35mm Equiv.) Zoom Lens Under Development
                    Panasonic is developing the first LEICA DG 100-400mm / F4.0-6.3 telephoto zoom lens (35mm camera equivalent: 200-800mm) for the Micro Four Thirds system standard to expand the lineup of DSLM (Digital Single Lens Mirrorless) digital interchangeable lenses.
                    The LEICA DG lenses are designed and developed under the stringent quality standard certified by Leica that boast excellent optical performance. Four single focal length LEICA DG lenses have already introduced to the market and have been highly acclaimed by users worldwide.
                    The new telephoto zoom achieves exceptional imaging performance over the entire zoom range. It also features high speed digital signal exchange at 240 fps to comply with the high-speed, high-precision AF (Auto Focus) with DFD (Depth From Defocus) technology on LUMIX G cameras. Together with the POWER O.I.S.(Optical Image Stabilizer), it lets users to focus on the target quickly to capture crisp, clear images. In addition, the new lens is both light and small and is splash/dust-proof to withstand heavy field use. As the new telephoto zoom lens excels in size and weight, it enables handheld 800mm (35mm camera equivalent) telephoto shooting without using a tripod.
                    This is what it looks like: http://bdevires.home.xs4all.nl/Image...400mm-lens.jpg
                    • #25
                      It will probably also be a good idea to wait for real-life test reports of forthcoming long primes and zooms on specific Oly and Pana bodies because of the trick combined sensor- and lens-based stabilisation options that may be available. They may not work across all combinations.
                      • #26
                        400mm @ f6.3 that's a pretty slow lens especially for a focal length that long. With 400mm you will be wanting to use a high shutter speed to avoid motion blur (the IS may counteract camera shake but there's no escaping using high shutter speeds to avoid motion blur). That will mean a high ISO in all but the best light, particularly if the lens needs to be stopped down to perform at it's best.
                        I'm still favouring the 300mm f4.
                        • #27
                          That's an issue with the reduced size and weight associated with M4/3. Even with cutting edge design you still get to the point that larger aperture telephoto lenses will eventually become too unwieldy for the camera, but in this case I don't think f6.3 unnessessarily slow with the latest low noise sensors. I regularly use a 600mm at f8 for birds going up to 16000 ISO without noise that can't be handled with most subjects.
                          • #28
                            True enough about modern sensors being able to handle ISO quite well, I use 5000 without any problems and still get good detail and saturation.
                            I'm certainly looking forward to the lenses coming out and seeing how they perform. Hopefully the new Pany won't just be a longer version of the 100-300, that is a good lens for the price make no mistake but it's not the most detailed lens at 300mm long distance.
                            • #29
                              The 300 is f4 at 300 or f5.6 with the converter on which gives 420 at f5.6 so only half a stop difference really. What we don't know is what is the Panny's f stop is at 300. ie is it too an f4 at 300 or slightly slower?
                              • #30
                                That is basically what the Oly 75-300 lens is, a longer version of the 40-150 as the f stop values are the same for the overlapping focal lengths. I wish they had made that lens brighter (f4-5.6), but it is conveniently lightweight for carrying purposes (& compact with my modified 40-150 hood).
                                I'll be watching how good these lenses perform & maybe I might get something else yet (money & wife allowing).
