Oly Macro Lens 35 Vs 50mm
  • Oly Macro Lens 35 Vs 50mm
    Both have a reputation for being slow focus and not so good in poor light.
    I'm want to buy one and can see no advantage in going Sigma route.
    Intended use: pin sharp flora and fauna and some portrait.
    Can I have your considered opinions please?
    David Styles
    Re: Oly Macro Lens 35 Vs 50mm
    oh dear - posted in the wrong area. Help!
    David Styles
      never mind the area...
      I would think (but don't have it) that the 35 would be a bit too close for portrait work
      My Kit (OK I'm a hoarder...)
      My places
        I've moved it to the Lens Focus area for you.
        Regarding the lenses, the 50mm is legendary for it's sharpness and IQ but the 35mm is no slouch and is a real bargain. You do get a better working distance with the 50mm and it's worth the extra if you can afford it. Either lens might be a bit too sharp for portraits, unless your subject has perfect, flawless skin!
        Focus is slow but for a lot of macro work this isn't a problem. Manual focusing using magnified live view is often better anyway.
          David Styles
            The 35 is good for portraits as well as being an excellent macro lens. It is very light and moderatly priced. I find it really good on an EP 2 as well.
              In defence of the 50mm's focusing speed - I find it perfectly acceptable (on a E510) when doing a group of shots at roughly the same distance. It is when you want to go straight (for example) from infinity to macro that it looses its way and can take for ever. In other words it would benefit from a focus limiting switch, but with sensible use there is no problem.
              However it can take a while on the P1, but the results are so good that I still use it on that camera.
              Incdently I always use single point AF when close up, and chose my own critical point of the image
              Roger
                Single point AF yes I'd agree that may be the best solution.
                Thanks
                David Styles
                  David Styles
                    In my opinion, the big difference is f:2.0 vs f:3.5. With f.2.0 you will be able to use lower ISO (=less noise) and control better the out of focus areas..
                      Slow focusing on the 50mm can be frustrating but as I use mine mainly for macro on MF this is not usually a problem. Although the 50mm is bright at f2 who uses that for macro work? Although a little softer and with some AF problems in low light the 70-300 is still very hard to beat!
                        I find the 35mm a great lens for both macro (its very sharp) and portraits, compared to the 50mm i suppose the f2 vs f3.5 is a major difference, but then on the other hand the 35mm can do 1:1 macro and the 50mm can only do 1:2
                        E-M10 Mk2 - 14-42mm EZ - 40-150mm ED - Falcon 8mm Fisheye - FL-36R
                        Wedding Photography Wales | Commercial Photography | Party Photographer Cardiff | Cheap Business Cards | Photoshop Training Cardiff
                          I have both and for portrait work there is no contest between the two, the 50mm wins hands down every time.
                          What you have to remember is the two times factor of 4/3's,not only for focal length but also for depth field.
                          So while 35mm (70mm) is not the ideal focal length for portraits it is usable if not to close to the subject. But it is the f3.5 (nearly f8) that is the problem as throwing backgrounds out of focus is a lot harder with the 35 mm.
                          Outdoor portrait taken with the 50mm at f2.5, with the 35mm that background would have been a lot more distracting.
                          That would be me David, for the more abstract/artistic macro work.
                          50mm at f2
                          Regards Paul.
                            Hi -
                            I've got both.
                            The 50 is nothing less than extraordinary, but "only" does 1:2 (1/2 life size), while the 35 does 1:1. For serious macro work, there is no substitute.
                            I do watch photography with the 35+Ring-LED light. Awesome results.
                            The 50 is, however, the lens to choose if you're only choosing one. The greater working distance is also important out in the real world...
                            JohnF
                              Focus speed is relative of course, I actually find the 50mm quite quick compared to my Sigma 150 (even with the focus limiter engaged).
                              I believe every 4/3 user should at least try the 50mm, it's a stunning little lens
                              Regards Huw
                              Olympus equipment
                              Capture One Pro
                              My flickr
