Hello everyone,
I hope you might be able to make some suggestions.
I have had an Olympus E420 for just over 3 years and it has been a great wee camera but tonight I went to turn it on for the first time in about 3 weeks and it has gone dead on me.
When I turn it on the lens focuses on whatever is in front of it but it then will not focus again (e.g. by half depressing the shutter button);
The screen on the back of the body does not turn on to access the menus or to review pictures on the memory (flash) card;
The buttons on the back of the body seem to have no effect in accessing menus etc.;
When the [liveview] button is pressed the mirror does not click up and I can still see through the viewfinder;
The camera is locked to whatever programme that the camera is on when it is turned on. If I turn the camera off and change it (say from P to A) then it will turn on in that programme but turning the selector switch on the top of the camera does nothing. I can tell from the viewfinder menu, which does still work.
The AEL lock button does make the AEL light on the viewfinder menu light up but I cant tell if it actually works.
The screen does give me the message that the the memory card door is open (when the door is open) and it gives a splashscreen about the SSWF when I turn the camera on without a memory card in it, so the screen hardware does work, making me think it is a software glitch.
I have tried the hardware reset (turn off, open card door, set to P, turn on, press OK and MENU at the same time twice, select yes to RESET) but aside from going back to beeping at me when the camera is focused (by itself when I first turn it on) it is still the same.
Reseating the lens doesn't seem to make any difference.
The battery is out now and I am going to charge up the battery fully (though it is fairly freshly charged) and let the internal sustain battery run flat (48 hours should be enough?).
Can any of you think or anything I could do to bring this camera back from the dead or do I need to get a new one?
Thank you for any input. I am
