Weakling
  • Weakling
    I weakened and got the M1X, arrived yesterday and went out in the cold with my 300mm Pro attached. Generally I like the camera, got more keepers than I would have with the EM1 Mk2. I normally shoot - 0.7 but today I found some shots were over exposed by a stop or more. I had turned the front wheel and changed my setting. Is there a way to lock the wheel? For me it was too easy to change the setting without realising.
    sigpicDave
    Re: Weakling
    Not weakened Dave, being bold
      Re: Weakling
      I have never had this problem with mine. I wonder if the front dial is too loose? Mine clicks into place and it is slightly harder to move than the rear dial.
      You can lock that dial with the lock lever - see Page 503 of the manual for how to configure it.
      Good luck!
      bengeo.com
        Re: Weakling
        I have never even seen a E-M1X so I am probably talking rubbish but could you be accidentally moving the duplicate dial on the other part of the grip?
          Re: Weakling
          Why didn't I think of that! I have the second one locked and just unlock it the few times I use that grip.
          bengeo.com
            Re: Weakling
            Well done Dave, it's a fantastic camera and I'm sure you'll have lot's of enjoyment with it.
            Looking forward to seeing some images.
              Re: Weakling
              Well done Dave. It's the wallet that is weak - not you.
                Congrats Dave, how do you get on with the sheer BULK it looks massive?
                  It is bigger, but I will probably only use it with the 300mm Pro and maybe the 40-150 Pro. When I can get out with it, I am enjoying it. Here are a couple using the 300mm Pro + 1.4 converter,
                  sigpicDave
                  • Dave in Wales
                    Dave in Wales commented
                    Superb quality i have to say, but is this a function of the body or lens or both.
                  Probably both Dave.
                  sigpicDave
