EM-1 Update
  • #31
    Re: EM-1 Update
    Hi Paul
    Well I didn't know either. Looked it up, and its a "scene mode". just gave it a try and it seems to set the camera settings and rattle of a number shots, I assume 8, and merge together. It looks as though you can not make exposure adjustments in this mode.
    • #32
      Re: EM-1 Update
      What is "handheld starlight"?
      Hi Paul
      Yes, and it pushes the ISO very high & at -0.3 Exp Comp. It gives you a resulting JPEG & will give you a single raw file (from the first frame) if saving that as well, where you can see the obvious noise from the high ISO exposure.
      • #33
        Re: EM-1 Update
        Hi, Heads up the EM-1 (v1) got a firmware update to 4.2.
        Correction: DO NOT UPDATE TO 4.2, there are problems, see rest of this thread
        Has 4.2 been retracted?
        Just looked at the updates, all I got was an update for my 12-50mm lens.
        4.1 was the latest update for the EM1, which is what I have already.
        Mj
        • #34
          Re: EM-1 Update
          Yes it's been pulled while Olympus investigate the problems it seems to be causing.
          • #35
            Re: EM-1 Update
            Firmware 4.3 is available now, fixing the problem.
            • #36
              Re: EM-1 Update
              Yep, & I've already updated mine to 4.3 (took 7 minutes & 33 seconds).
