EM-1 Update
  • #16
    Re: EM-1 Update
    Originally posted by CJJE View Post
    Thanks Ross,
    None of the reported gains of the update are that important to me, so I don't have to rush to update my camera. But it's good to know that it'll be a simple task when I get round to it.
    Not even "Improved stability of exposure when shooting videos"?
    • #17
      Re: EM-1 Update
      I've updated mine (took 7 minutes to download) & everything seems fine. Apparently there are some saying there might be issues, such as problems during Focus Stacking with the F4 300mm lens & also Keystone Compensation. I've tried both with my 40-150 Pro lens (with MC14) & both seem to be fine. In fact, I was hand holding the gear for Focus Stacking & it still combined the images, even though there was some movement. I hadn't tried Focus Stacking on that lens beforehand though, being only a few weeks old & not seeing any need for it so far.
      • #18
        Re: EM-1 Update
        Nope, I'm a stills photographer not a videographer...
        • #19
          Re: EM-1 Update
          I see that 43rumors.com are reporting problems with v4.2:
          As reported by many readers (including Pen And tell and Denjw) the 4.2 firmware update for the E-M1 contains a major bug on. It locks down and creates corrupted images when using those functions:
          – Focus Stacking
          – Keystone
          – HDR
          – Starlight mode
          So please do not install the firmware. Or if you already installed it don’t use those functions until Olympus will release a bug fix (hopefully soon).
          So, it could be as well to delay updating unless you REALLY need it?
          • #20
            Re: EM-1 Update
            I've just tried focus stacking with the 40-150 Pro and it locks up in the same way as the 300mm. Ho hum...
            • #21
              Re: EM-1 Update
              I think that you will find that differences in magnification are more of an issue than framing with hand-held stacks.
              Harold
              • #22
                Re: EM-1 Update
                Apparently there is another scenario that can cause it to show up.
                According to Reinhard Wagner from the German Oly forum, the bugs occur if RecView (display of the image right after the shot) is disabled.
                I don't have mine disabled.
                • #23
                  Re: EM-1 Update
                  Mine is disabled!
                  • #24
                    Re: EM-1 Update
                    Mine is disabled!
                    Better enable it (RecView) to 0.5 sec if you want to perform those other functions then!
                    • #25
                      Re: EM-1 Update
                      Hi, Heads up the EM-1 (v1) got a firmware update to 4.2.
                      Paul, can you please edit you're first post to tell everyone not to update because of this apparent bug in the FW. Also advise Admin too.
                      • #26
                        Re: EM-1 Update
                        Have amended original message as you suggested.
                        Many thanks
                        • #27
                          Re: EM-1 Update
                          Many thanks
                          Thanks for that. It may save others from heartache. For myself, because I have Record View enabled (to 0.5 sec) I am not having any problems. I have also tried video with the 40-150 Pro lens without issue & now, the other function reported to have issues, Hand-held Starlight.
                          Here's a shot out to my backyard with it.
                          Here are links to reports of the problem. http://www.43rumors.com/bug-warning-...-on-your-e-m1/
                          https://www.dpreview.com/forums/thread/4086175
                          • #28
                            Re: EM-1 Update
                            Hi
                            I've now tried "rec view" set to 0.3 sec and all seems to work correctly. So it seems its on;y when 'rec view" is set to 'off' that problems arise.
                            Hope this helps
                            • #29
                              Re: EM-1 Update
                              Hi again
                              Out of interest, the updated firmware to the EM-5 v2 all seems to work OK, the problems as with EM-1. do not occur with "rec view" at zero.
                              • #30
                                Re: EM-1 Update
                                What is "handheld starlight"?
